I tested Samsung 250 GB EVO 850 SSD using “sudo hdpram -Tt /dev/sdax” where sdax was formatted with EXT4 and got “Timing buffered disk reads = 129MB/s”.
The same SSD was tested on Tegra X1 base Shield Pro and produced “Timing buffered disk reads = 250MB/s”.
Both the TX1 and the Shield Pro have L4T 24.2.1 kernel/rootfs.
Why SATA throughput on TX1 is so low?
Has anyone tested throughput of SSDs on TX1 with L4T24.2?
I found the problem was due to those eSata/USB docks/adapters. Since CEI carrier card does not have SATA power, I had to use those docks/adapters to get power. It appears those adapters only support SATA Gen1.
I found a SATA power cable to get power from a PC power supply and used a SATA cable between CEI carrier card and SSD, and got 261MB/S.
