Hi, it’s my first post on this forum so I’m sorry if I’m unclear. I think I need to describe a bit the project first so I’m a engineering student in embedded system and for my graduation work I must realize a sort of cluster with TX1, TK1 and others embedded board. The goal is to bring a support to a informatic class, where the student would be apple to connect remotely and work with many architecture without any risk of hardware mishandling. Since it would be different courses on it, I must use a master server that would be able to reflash/clonning/deploy environnement/monitor on remote request.
So here we are, I have the master server running a Debian 8 with 3 KVM VPS:
- A Ubuntu 16.04 desktop to flash TX1;
- A Ubuntu 14.04 desktop to flash TK1;
- A PfSense for firewall purpose;
I am to the point that TX1 and TK1 are well assigned to the guest OS when in recovery mode, they appears in lsusb with HighSpeed 480mb/s, JetPack can mount the 15Gb system without any problems and start the flash but it stuck every time at the same moment (not exactly the same between TX and TK)…
lsusb on host (TX1):
root@HEH-SC-Server:/home/sangoku# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04f2:1013 Chicony Electronics Co., Ltd
Bus 001 Device 004: ID 0955:7721 NVidia Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@HEH-SC-Server:/home/sangoku# lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
|__ Port 2: Dev 4, If 0, Class=Vendor Specific Class, Driver=, 480M
|__ Port 3: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 12M
lsusb on the guest (TX1):
sangoku@VPS-Ubuntu-16:~$ lsusb
Bus 001 Device 002: ID 0955:7721 NVidia Corp.
sangoku@VPS-Ubuntu-16:~$ lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 2: Dev 2, If 0, Class=Vendor Specific Class, Driver=, 480M
Flash output:
-- Total: -----------------------------------------------------------
2504 CHUNK 15032385536(3670016 blks) ==> 3356878204(819543 blks)
done.
system.img built successfully.
Existing tbcfile(/home/sangoku/Desktop/NVidia/64_TX1/Linux_for_Tegra_64_tx1/bootloader/nvtboot_cpu.bin) reused.
copying cfgfile(/home/sangoku/Desktop/NVidia/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/cfg/gnu_linux_tegraboot_emmc_full.xml) to flash.xml... done.
creating gpt(ppt.img)...
*** GPT Parameters ***
device size -------------- 31276924928
bootpart size ------------ 8388608
userpart size ------------ 31268536320
Erase Block Size --------- 2097152
sector size -------------- 4096
Partition Config file ---- flash.xml
Visible partition flag --- GP1
Primary GPT output ------- PPT->ppt.img
Secondary GPT output ----- GPT->gpt.img
Target device name ------- none
*** PARTITION LAYOUT(23 partitions) ***
[ BCT] BH 0 8191 4.0MiB
[ NVC] BH 8192 16383 4.0MiB nvtboot.bin
[ PPT] UH 0 4095 2.0MiB
[ GP1] UH 4096 8191 2.0MiB
[ APP] UH 8192 29368319 14336.0MiB system.img
[ TBC] UV 29368320 29372415 2.0MiB nvtboot_cpu.bin
[ EBT] UV 29372416 29380607 4.0MiB u-boot-dtb.bin
[ BPF] UV 29380608 29384703 2.0MiB bpmp.bin
[ WB0] UV 29384704 29396991 6.0MiB warmboot.bin
[ RP1] UV 29396992 29405183 4.0MiB tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
[ TOS] UV 29405184 29417471 6.0MiB tos.img
[ EKS] UV 29417472 29421567 2.0MiB
[ FX] UV 29421568 29425663 2.0MiB
[ SOS] UV 29425664 29466623 20.0MiB
[ EXI] UV 29466624 29597695 64.0MiB
[ LNX] UV 29597696 29728767 64.0MiB
[ DTB] UV 29728768 29736959 4.0MiB tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
[ NXT] UV 29736960 29741055 2.0MiB
[ MXB] UV 29741056 29753343 6.0MiB
[ MXP] UV 29753344 29765631 6.0MiB
[ USP] UV 29765632 29769727 2.0MiB
[ UDA] UV 29769728 61067263 15282.0MiB
[ GPT] UH 61067264 61071359 2.0MiB
copying flasher(/home/sangoku/Desktop/NVidia/64_TX1/Linux_for_Tegra_64_tx1/bootloader/t210ref/cboot.bin)... done.
Existing flashapp(/home/sangoku/Desktop/NVidia/64_TX1/Linux_for_Tegra_64_tx1/bootloader/tegraflash.py) reused.
*** Flashing target device started. ***
./tegraflash.py --bl cboot.bin --bct P2180_A00_LP4_DSC_204Mhz.cfg --odmdata 0x84000 --bldtb tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb --applet nvtboot_recovery.bin --boardconfig board_config_p2597-devkit.xml --cmd "flash;reboot" --cfg flash.xml --chip 0x21
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0000 ] Generating RCM messages
[ 0.0435 ] tegrarcm --listrcm rcm_list.xml --chip 0x21 --download rcm nvtboot_recovery.bin 0 0
[ 0.0442 ] RCM 0 is saved as rcm_0.rcm
[ 0.0575 ] RCM 1 is saved as rcm_1.rcm
[ 0.0575 ] List of rcm files are saved in rcm_list.xml
[ 0.0575 ]
[ 0.0575 ] Signing RCM messages
[ 0.0678 ] tegrasign --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0687 ] Assuming zero filled SBK key
[ 0.1603 ]
[ 0.1603 ] Copying signature to RCM mesages
[ 0.1611 ] tegrarcm --chip 0x21 --updatesig rcm_list_signed.xml
[ 0.1621 ]
[ 0.1621 ] Parsing partition layout
[ 0.2455 ] tegraparser --pt flash.xml
[ 0.3045 ]
[ 0.3045 ] Creating list of images to be signed
[ 0.3236 ] tegrahost --chip 0x21 --partitionlayout flash.bin --list images_list.xml
[ 0.7276 ]
[ 0.7276 ] Generating signatures
[ 0.7298 ] tegrasign --key None --list images_list.xml --pubkeyhash pub_key.key
[ 0.7336 ] Assuming zero filled SBK key
[ 0.8114 ]
[ 0.8465 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.cfg --chip 0x21
[ 0.8473 ] Copying Sdram info from 0 to 1 set
[ 0.8896 ] Copying Sdram info from 1 to 2 set
[ 0.8896 ] Copying Sdram info from 2 to 3 set
[ 0.8896 ]
[ 0.8897 ] Updating boot device parameters
[ 0.8904 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatedevparam flash.bin
[ 0.8977 ] Warning: No sdram params
[ 0.8977 ]
[ 0.8977 ] Updating bl info
[ 0.9018 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updateblinfo flash.bin --updatesig images_list_signed.xml
[ 0.9055 ]
[ 0.9055 ] Updating secondary storage information into bct
[ 0.9071 ] tegraparser --pt flash.bin --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.9105 ]
[ 0.9105 ] Updating board information from board config into bct
[ 0.9143 ] tegraparser --boardconfig board_config_p2597-devkit.xml --chip 0x21 --updatecustinfo P2180_A00_LP4_DSC_204Mhz.bct
[ 0.9180 ]
[ 0.9182 ] Updating Odmdata
[ 0.9191 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatefields Odmdata = 0x84000
[ 0.9201 ] Warning: No sdram params
[ 0.9202 ]
[ 0.9203 ] Get Signed section bct
[ 0.9214 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --listbct bct_list.xml
[ 0.9332 ]
[ 0.9333 ] Signing BCT
[ 0.9352 ] tegrasign --key None --list bct_list.xml --pubkeyhash pub_key.key
[ 0.9361 ] Assuming zero filled SBK key
[ 0.9361 ]
[ 0.9361 ] Updating BCT with signature
[ 0.9368 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatesig bct_list_signed.xml
[ 0.9396 ]
[ 0.9397 ] Copying signatures
[ 0.9406 ] tegrahost --chip 0x21 --partitionlayout flash.bin --updatesig images_list_signed.xml
[ 0.9414 ] Run tegrabct to update tboot signature in bct
[ 0.9542 ]
[ 0.9543 ] Updating BFS information
[ 0.9551 ] tegrabct --bct P2180_A00_LP4_DSC_204Mhz.bct --chip 0x21 --updatebfsinfo flash.bin
[ 0.9732 ]
[ 0.9733 ] Boot Rom communication
[ 0.9763 ] tegrarcm --chip 0x21 --rcm rcm_list_signed.xml
[ 0.9771 ] BR_CID: 0x32101001640d06c92000000009fd0240
As you can see the TX1 freeze at Boot Rom communication but this is over my knowledge, I can’t understand by myself from what it could be come from. For the TK1, it’s worse because it freeze just after the ./tegraflash.py message (there is no “[0.000] Generating RCM messages”)… I tried with different KVM usb controller (ich9 ehci and nec-xhci) and since the usb work at the flash start I can’t realize why it freeze so I hope someone here can tell me what I missed in the process? Or perhaps a way/command to access error log on what could be wrong? It is the same result if I just use the clonning process.
I can perfectly flash without any problem from a VM in VirtualBox on my computer but I need it to be flashed from the headless server which would be in the rack cabinets (VNC on VPS). It is impossible to reflash manually every time a student would mess up an OS because there would be 20 TK1 and 4 TX1.
Host config (if helpfull about virtualization limit):
- Xeon E3-1225;
- MB Gigabyte MW21-SE0;
Thank you to anyone who can help me!
