I’m trying to do the same on TX2. I compiled and installed the “overlay” module on Jetson TX2 L4T27.1 kernel 4.4.15 following this tutorial:
http://www.jetsonhacks.com/2017/03/25/build-kernel-and-modules-nvidia-jetson-tx2/
I was able to load the module at boot by adding it in /etc/modules, /etc/initramfs-tools/initramfs.conf and updating initramfs:
sudo update-initramfs -u.
now lsmod gives:
Module Size Used by
fuse 89120 3
bnep 15477 2
bluetooth 552900 7 bnep
bcmdhd 7637079 0
pci_tegra 72709 0
overlay 36906 0
bluedroid_pm 13874 0
I edited the /etc/overlayroot.conf with the simplest “tmpfs” setting but nothing happens; the “mount” command output remains unchanged:
/dev/mmcblk0p1 on / type ext4 (rw,relatime,data=ordered)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
none on /dev type devtmpfs (rw,relatime,size=7969536k,nr_inodes=1992384,mode=755)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/debug type cgroup (rw,nosuid,nodev,noexec,relatime,debug)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=804240k,mode=700,uid=1000,gid=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
tmpfs on /run/user/1001 type tmpfs (rw,nosuid,nodev,relatime,size=804240k,mode=700,uid=1001,gid=1001)
I also tried to append overlayroot=tmpfs to kernel parameters, in file /boot/extlinux/extlinux.conf
