I’m using windows but the same stuff applies to Linux :-)
Number of things really.
Downloaded the NVIDIA Tegra Linux Driver Package Development Guide and unpack
https://developer.nvidia.com/embedded/dlc/l4t-documentation-24-2
Unpack the above link and open the Start_L4T_Docs.html file in a browser
Click “Lauterbach Debuging Scripts” on the menu on the left then click the “Lauterbach scripts” link just below the heading. This will get you lauterbach.tar.gz.
Unpack this and extract the files into a convenient directory for use later
For the TX1 you must create a root user to enable the debugging in sysfs (sudo does not work!)
$ sudo passwd root
Enter and confirm a root password (you only need to do this once obviously)
Start a root shell
$ su
echo 0 > /sys/devices/system/cpu/cpuquiet/tegra_cpuquiet/enable
echo 1 > /sys/kernel/debug/cpuidle_t210/fast_cluster_states_enable
echo 1 > /sys/kernel/debug/cpuidle_t210/slow_cluster_states_enable
echo 1 > /sys/kernel/debug/clock/csite/state
$ echo 1 > /sys/kernel/debug/tegra_wdt/disable_wdt_reset
$ exit
You will need to do this part every time you reset/power cycle the board. I haven’t found a way to automatically open a root shell and run this script. You could recompile the kernel/dtb to setup like this I suppose?
You will need to make a clean install of the Trace32 software from Lauterbach and install only the arm64 components. Apparently if you mix arm and arm64 things go horribly wrong (according to Lauterbach uk)
Attach the Lauterbach to the board and start Trace32
Nvidia supply a script in the tar.gz called cpu_kernel_attach.cmm. You need to modify this script to suit where you have installed the Trace32 software and where your kernel source and vmlinux is. I build the Nvidia stuff on a Linux Mint VM as I hate Ubuntu UI and I have the home directory as a samba share in windows Below is my version of the script…
; Copyright © 2012-2014, NVIDIA CORPORATION. All rights reserved.
; Lauterbach TRACE32 debugger script to set user-specific parameters:
; For NVIDIA internal use only. Customers should not use this script
; unless NVIDIA explicitly directs them to do so.
; Lauterbach TRACE32 debugger script to attach to CPU with kernel symbols loaded.
; Path to compiled kernel
&KERNEL_ELF=“Z:\Sandbox\Islay\64_TX1\Linux_for_Tegra_64_tx1\sources\kernel_source\vmlinux”
; Path to the lauterbach scripts
&TARGET_SOC_PATH=“C:\Sandbox_git_new\LauterbachScripts_14_6\tx1”
; TX1 model
&TARGET_SOC=“t21x”
; Directory you installed Trace32 to
&T32SYS=“C:\t32”
; Setup JTAG for multicore CPU.
;do &(TARGET_SOC_PATH)/&(TARGET_SOC)/&(TARGET_SOC)_cpu_mp_jtag_setup.cmm
; Setup JTAG for single core CPU.
do &(TARGET_SOC_PATH)/&(TARGET_SOC)/&(TARGET_SOC)_cpu_jtag_setup.cmm
global &LINUX_AWARENESS
; Setup for kernel virtual addressing mode.
if “&TARGET_SOC”!=“t21x”
do virtual_setup.cmm
&LINUX_AWARENESS="&T32SYS/demo/arm/kernel/linux/linux-3.x"
else
&LINUX_AWARENESS="&T32SYS/demo/arm64/kernel/linux/linux-3.x"
sYmbol.RESet
; Load the kernel symbols symbols. The strippart variable removes components from the path until
; you get the path to be the relative to your kernel source tree
; On my system /strippart 9 removes the “Z:\Sandbox\Islay\64_TX1\Linux_for_Tegra_64_tx1\sources\kernel_source” from the path
print “Loading &KERNEL_ELF symbols”
data.load.elf &KERNEL_ELF /NOCODE /gnu /strippart 9 /lowerpath
IF “&BUILDTOP”!=""
SYMBOL.SOURCEPATH.TRANSLATE “&BUILDTOP” “&TOP”
IF ("&LOAD_SAVED_WINDOWS"==“TRUE”)
; Restore saved window configuration (this is always saved in the $T32SYS directory – don’t change the path)
do &T32SYS/windows.cmm
system.mode.attach
task.setdir &LINUX_AWARENESS
task.config &LINUX_AWARENESS/linux3
menu.ReProgram &LINUX_AWARENESS/linux.men
if “&TARGET_SOC”==“t21x”
menu.ReProgram &T32SYS/menarmv8a.men
; Optionally load saved breakpoints
;do &TARGET_SOC_PATH/…/breaks.cmm
go
