I can’t connect to my WiFi network with the wpa_cli tool. I am using the guide here: https://shapeshed.com/linux-wifi/. Nothing happens after the
enable_network 0
step. Noticed that when I start wpa_cli it says
Selected interface 'p2p-dev-wlan0'
which I do not see in the output of
ifconfig -a
or
ip a
Any help would be appreciated, thank you.
Hi vectrasoft,
Do you add p2p-dev-wlan0 interface?
In /etc/network/interfaces, Add below
auto p2p-dev-wlan0
iface p2p-dev-wlan0 inet static
address 10.10.0.1
netmask 255.255.255.0
That did nothing.
I realized wpa_cli chose the p2p-dev-wlan0 interface by default, so I tried:
wpa_cli -i wlan0
This allowed me to configure the network, enable it, and successfully connect - BUT - save_config always fails. This is a problem because a failing save_config means every boot of the TX1 I need to manually configure the network - not good for a robotics project.
Can you explain what the p2p-dev-wlan0 interface is? Is there a way to use wlan0 interface and get it properly configured permanently?
Solved! /etc/network/interfaces:
auto wlan0
iface wlan0 inet dhcp
wpa-ssid MYSSID
wpa-psk "PASSWORD"
