Hello all,
We develop a product that work with a TX1 system.
For this test I am working with a TX1 with the development board kit, Ubuntu 16.04.
Jetson R28 (release), REVISION: 1.0, BOARD: t210ref, EABI: aarch64.
The problem is the following:
I am not able to connect to any router network throw WIFI. However, I can connect to my mobile phone as hostpot using the Shared WIFI. Moreover, I have no problem with ethernet connection.
dmesg outputs:
[ 4541.864964] connect failed event=0 e->status 1 e->reason 0
[ 4541.892166] CFG80211-ERROR) wl_bss_connect_done : Report connect result - connection failed
[ 4555.037955] CFG80211-ERROR) wl_notify_pfn_status : >>> PNO Event
And Network-manager is at the last available version: 1.2.6
Additional info:
I can do: “sudo nmcli dev wifi list” and I get the expected answer
the iwconfig command returns: wlan0 no wireless extensions.
Any help is appreciated, I have looking for the answer on the forum throw all googleable with no luck…
thanks so much
PS: Re flashing an update JETSON pack is not a possibility.
Manel
