Does anyone build DJI SDK on TX1 ?
If so,can you show me how to build it?
Thank you very much
br
ccchen
Thank you very much
br
ccchen
ccchen,
It look like tx1 is already supported in the SDK,
https://github.com/dji-sdk/Guidance-SDK/commit/a22b00011cdb50acdeebdf5725bddffb7784d050
chijen,
I tried to compile the guidance example as described here: https://developer.dji.com/guidance-sdk/documentation/quick-start/run-examples.html, however, I receive the following linking error:
/usr/bin/ld: skipping incompatible /home/ubuntu/UAV/Guidance-SDK/so/TX1/libDJI_guidance.so when searching for -lDJI_guidance
/usr/bin/ld: cannot find -lDJI_guidance
My Jeston TX1 is flashed with the latest L4T image.
Would it be possible to have a new library built for the TX1 for the latest L4T image?
Thanks,
-M.
BTW, the Jetson TX1 L4T image I’m using is 24.2.1.
Found a temp fix: down grade to Jetpack 2.1 for the TX1.
