BACKLIGHT_DEVICE_PRE_BRIGHTNESS_CHANGE
kernel/kernel-4.9/include/linux/backlight.h: BACKLIGHT_DEVICE_PRE_BRIGHTNESS_CHANGE,
kernel/kernel-4.9/drivers/video/backlight/lp855x_bl.c: BACKKLIGHT_DEVICE_PRE_BRIGHTNESS_CHANGE,
kernel/kernel-4.9/drivers/video/backlight/pwm_bl.c: BACKLIGHT_DEVICE_PRE_BRIGHTNESS_CHANGE,
is used in lp855x_bl.c and pwm_pl.c but no other code services the request. this causes
if (pb->notify)
brightness = pb->notify(pb->dev, brightness);
to always return zero, and pwm_config never gets called.
@linuxdev do you know the code that will process the notify
