My custom board with mipi-dsi display works great if in graphical.target mode. Changed to multi-user.target and am not getting any prompt on my display.
Also tried to do a ctl-alt-f4 in graphical.target mode and got no prompt, so appears to be a mipi-dsi problem, anyone else seen/fixed
am I missing something in the driver to make multi-user.target happy?
the backlight is on, so the display should work, but I think the smoking gun is the ctl-alt-f4 not working in graphical.target
Thanks,
Terry
More information.
When I do the ctl-alt-f4 dmesg shows.
[57357.171589] tegradc 15200000.nvdisplay: blank - powerdown
[57358.656335] tegradc 15210000.nvdisplay: blank - powerdown
[57358.720626] extcon-disp-state external-connection:disp-state: cable 47 state 0
[57358.720629] Extcon AUX1(HDMI) disable
[57358.742219] tegra_nvdisp_handle_pd_disable: Powergated Head2 pd
[57358.742306] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[57358.742883] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[57358.744469] tegradc 15200000.nvdisplay: blank - powerdown
Everything gets disabled/blanked, powerdown, nothing is working so of course nothing is displayed.
When I do ctl-alt-f1 dmesg shows.
[57406.297646] tegradc 15200000.nvdisplay: blank - powerdown
[57406.297661] tegradc 15200000.nvdisplay: unblank
[57406.298345] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[57406.300328] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[57406.331867] tegradc 15200000.nvdisplay: DSI: HS clock rate is 194000
[57406.805926] tegradc 15200000.nvdisplay: unblank
[57406.805947] tegradc 15210000.nvdisplay: blank - powerdown
[57406.805958] tegradc 15210000.nvdisplay: unblank
[57406.806082] tegra_nvdisp_handle_pd_enable: Unpowergated Head2 pd
[57406.810539] Parent Clock set for DC plld2
[57406.814061] tegradc 15210000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[57406.815402] tegradc 15210000.nvdisplay: hdmi: get RGB quant from EDID.
[57406.815409] tegradc 15210000.nvdisplay: hdmi: get YCC quant from EDID.
[57406.850955] extcon-disp-state external-connection:disp-state: cable 47 state 1
[57406.850958] Extcon AUX1(HDMI) enable
[57406.851028] tegradc 15210000.nvdisplay: unblank
Things go down but are brought back up,
Real question does ctl-alt-f4 work on normal Nvidia hdmi systems?
Thanks,
So far as I know the text consoles do work when using a CTRL-ALT-F#. There have been issues with forcing purely text mode, especially in earlier releases. This URL is probably of use:
https://devtalk.nvidia.com/default/topic/1001007/jetson-tx2/is-there-a-way-to-boot-ubuntu-16-04-into-command-line-only-do-not-start-gui-/post/5285473/#5285473
