I have followed the instructions for running the Jetson TX2 as Jetson TX2-4GB as referenced here:
https://developer.nvidia.com/embedded/jetson-tx2-4gb
After running “sudo ./flash.sh jetson-tx2-as-4GB mmcblk0p1”, the device does boot and show 4GB of physical memory. However, the next step indicates using JetPack to install SDK components. This step seems to also reflash the OS at which point the system goes back to showing 8GB of physical memory.
How can I get the JetPack SDK components installed while still configured as a 4GB unit?
