Hello!
I am having strange problems with the Jetson TX2 and the TX1, when I connect two network cards. When I, for example, use a TX2 on its developer board and connect a usb3.0 network dongle and set up a network bridge, the driver crashes or at least throws exceptions as soon as I generate traffic across the bridge.
Sometimes the system recovers, most of the time it doesn’t and I need to reboot. I would really love to have the possibility to route full GigE traffic through the Jetson every once in a while.
edit: I am using a custom compiled 4.4.38 kernel (nvidia sources)
dmesg output:
[Dec19 13:02] NETDEV WATCHDOG: eth1 (r8152): transmit queue 0 timed out
[ +0.006559] ------------[ cut here ]------------
[ +0.004666] WARNING: at ffffffc0009a376c [verbose debug info unavailable]
[ +0.006853] Modules linked in: bcmdhd pci_tegra bluedroid_pm
[ +0.007305] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.38 #1
[ +0.005977] Hardware name: quill (DT)
[ +0.003701] task: ffffffc0011ecec0 ti: ffffffc0011dc000 task.ti: ffffffc0011dc000
[ +0.007564] PC is at dev_watchdog+0x2ac/0x2bc
[ +0.004401] LR is at dev_watchdog+0x2ac/0x2bc
[ +0.006035] pc : [<ffffffc0009a376c>] lr : [<ffffffc0009a376c>] pstate: 60000045
[ +0.010773] sp : ffffffc0011dfb40
[ +0.004960] x29: ffffffc0011dfb40 x28: ffffffc1e32b63b8
[ +0.007005] x27: ffffffc0011b0ab8 x26: 0000000000000280
[ +0.006941] x25: 00000000ffffffff x24: 0000000000000000
[ +0.007021] x23: ffffffc1e32b63a0 x22: ffffffc00135e000
[ +0.007024] x21: ffffffc1e4e07c00 x20: ffffffc1e32b6000
[ +0.007015] x19: ffffffc0011e2000 x18: ffffffc000b82f38
[ +0.006966] x17: 00000000a9adee6f x16: ffffffc000b12a60
[ +0.006912] x15: ffffffc000b12a60 x14: 7420302065756575
[ +0.006925] x13: 712074696d736e61 x12: 7274203a29323531
[ +0.006953] x11: 3872282031687465 x10: 203a474f44484354
[ +0.006922] x9 : 0000000000000386 x8 : 0000000000000002
[ +0.006894] x7 : 0000000000000000 x6 : 0000000000000049
[ +0.006850] x5 : 0000000000000000 x4 : 0000000000000000
[ +0.006837] x3 : 0000000000000000 x2 : 0000000000000102
[ +0.006848] x1 : ffffffc0011dc000 x0 : 0000000000000039
[ +0.009820] ---[ end trace e2f3a7c9f7da4dad ]---
[ +0.006114] Call trace:
[ +0.003893] [<ffffffc0009a376c>] dev_watchdog+0x2ac/0x2bc
[ +0.006839] [<ffffffc0001055e4>] call_timer_fn+0x50/0x1bc
[ +0.006795] [<ffffffc000105910>] run_timer_softirq+0x1ac/0x2a4
[ +0.007206] [<ffffffc0000a8974>] __do_softirq+0x10c/0x368
[ +0.006747] [<ffffffc0000a8e28>] irq_exit+0x84/0xdc
[ +0.006198] [<ffffffc0000f45e4>] __handle_domain_irq+0x6c/0xb4
[ +0.007075] [<ffffffc0000815dc>] gic_handle_irq+0x5c/0xb4
[ +0.006646] [<ffffffc000084740>] el1_irq+0x80/0xf8
[ +0.006063] [<ffffffc0007b8594>] cpuidle_enter+0x18/0x20
[ +0.006578] [<ffffffc0000e7a74>] call_cpuidle+0x28/0x50
[ +0.006413] [<ffffffc0000e7c18>] cpu_startup_entry+0x17c/0x340
[ +0.007063] [<ffffffc000b020e0>] rest_init+0x84/0x8c
[ +0.006202] [<ffffffc00109797c>] start_kernel+0x39c/0x3b0
[ +0.006616] [<0000000080b08000>] 0x80b08000
[ +0.005555] r8152 2-1:1.0 eth1: Tx timeout
[ +5.722539] r8152 2-1:1.0 eth1: Tx timeout
The bridge is configured as following in network/interfaces:
# Bridging dhcp configuration
# eth0 and eth1 are bridged together
# Set up interfaces manually, avoiding conflicts with, e.g., network manager
iface eth0 inet manual
iface eth1 inet manual
# Bridge setup
auto br0
iface br0 inet dhcp
bridge_waitport 10 eth0 eth1
bridge_ports eth0 eth1
Here some more information on the network configuration:
$ brctl showstp br0
br0
bridge id 8000.00044b8d4688
designated root 8000.00044b8d4688
root port 0 path cost 0
max age 20.00 bridge max age 20.00
hello time 2.00 bridge hello time 2.00
forward delay 15.00 bridge forward delay 15.00
ageing time 300.00
hello timer 0.00 tcn timer 0.00
topology change timer 0.00 gc timer 146.62
flags
eth0 (1)
port id 8001 state forwarding
designated root 8000.00044b8d4688 path cost 4
designated bridge 8000.00044b8d4688 message age timer 0.00
designated port 8001 forward delay timer 0.00
designated cost 0 hold timer 0.00
flags
eth1 (2)
port id 8002 state forwarding
designated port 8002 forward delay timer 0.00
flags
$ sudo ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Supports Wake-on: ug
Wake-on: g
Link detected: yes
$ sudo ethtool eth1
Settings for eth1:
Supported ports: [ MII ]
1000baseT/Full
Supported pause frame use: No
1000baseT/Full
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 32
Transceiver: internal
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00007fff (32767)
drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol
Link detected: yes
$ sudo lshw -C network
*-network:0 DISABLED
description: Ethernet interface
physical id: 3
logical name: dummy0
serial: 6a:16:ac:0a:84:cf
capabilities: ethernet physical
configuration: broadcast=yes driver=dummy driverversion=1.0
*-network:1 DISABLED
physical id: 4
logical name: wlan0
serial: 00:04:4b:8d:46:86
configuration: broadcast=yes driver=wl driverversion=0 multicast=yes
*-network:2
physical id: 5
logical name: eth1
serial: 00:e0:92:00:19:99
capacity: 1Gbit/s
capabilities: ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v2.03.3 (2015/01/29) duplex=full link=yes multicast=yes port=MII speed=1Gbit/s
*-network:3
physical id: 6
logical name: eth0
serial: 00:04:4b:8d:46:88
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=eqos duplex=full link=yes multicast=yes port=MII speed=1Gbit/s
