TX2 and Xavier Camera Connector
We make a camera interface extension board based on Xavier DevKit, It’s just the adapter that leads the camera pins out.
When I plug this adapter into the TX2 devkit and press the Power button, the TX2 won’t start. Remove the camera adapter board, TX2 can start normally.
I compareTX2 camera connector to Xavier connector , Found TX2 63pin and 64pin connected to Xavier GND, So I removed the 63pin and the 64 pin. But when the adapter board is inserted into the TX2, the TX2 still cannot start.
What might be causing this?
Hi, they are different designs. You can check the schematic of Xavier carrier (P2822) and TX2 carrier (P2597) in DLC for the detail difference. You might need to change your camera board design accordingly.
