Tx2 Benchmarks error
I follow this github
github.com
; execute sudo python3 benchmark.py --all --csv_file_path benchmark_csv/tx2-nano-benchmarks.csv --model_dir models --jetson_devkit tx2 --gpu_freq 1122000000 --power_mode 0 --precision fp16 – jetson_clocks;
Log information prompt:
log1.txt (1.6 KB)
According to the information prompted by the execution command, I checked the logs in models. Some of the logs are as follows:
ssd-mobilenet-v1_b1_ws1024_gpu.txt (4.3 KB)
I looked at all the logs, and they all indicate that the corresponding engine file is missing. What is the reason? Thanks
The error indicates that the engine file cannot be saved/opened.
[04/26/2024-14:01:32] [E] Error opening engine file: models/ssd-mobilenet-v1_b1_ws1024_gpu.engine
Please help to check if the script has written permission for the folder.
hello, AastaLLL
I have solved it, thank you for your reply;
The specific reason is this command:
You need to pass the absolute path to it.
