TX2 Boot Without Sequence Control
Dear friends,
I am currently designing a kiosk that will use a Jetson TX2 module. Upon reviewing the datasheet for the Jetson TX2 module, I came across a sequence diagram. My goal is to have the Jetson module turn on automatically when power is inserted. I am wondering if it is possible to configure the boot control using a simple sequencer and delay IC, or if I will need to use an MCU to control it.
Thank you for your assistance.
You can use other designs than MCU only if the power sequence can be followed well.
