TX2 can not boot up
Hi all,
After running for a long time, TX2 suddenly doesn’t work. After restarting, it can’t enter the system.
Connecting the serial port, it is found that the printing is as follows:
!!! Exception !!! [lr:0x40021cea, dfar:0x22150a0 , dfsr:0x1808 ]
MB1-BIT() boot status dump:0000000000000000000000000000000000
Last seen error : 0x00000000
Moreover, TX2 cannot enter recovery mode
According to the serial port log, what happened to TX2? Can someone locate the cause of this problem?
Regards
If even cannot enter recovery mode, then it is possible a hardware issue. We cannot help from software side.
How did you know it cannot enter recovery mode? lsusb does not show anything?
Hi XavierSu,
