[tx2] can't receive output stream using DS 4.0
my input type is mode 4 with a HikVision IPC camera .And I use yolo for detection,I want to make the result output as rtspstreaming.
Here are my settings:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=4
uri=rtsp://admin:catlab2018@10.48.76.113:554
#uri=file://1.mp4
num-sources=1
gpu-id=0
(0): memtype_device - Memory type Device
(1): memtype_pinned - Memory type Host Pinned
(2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=mp4 2=mkv
#container=2
#1=h264 2=h265 3=mpeg4
only mpeg4 is supported right now.
codec=1
sync=0
#source-id=0
bitrate=4000000
set below properties in case of RTSPStreaming
rtsp-port=8554
#udp-port=5400
I can see the result of detection on screen, and when i use netstatus , it shows port 8554 works well.
but if I use vlc with the location rtsp://localhost:8554/ds-test,the connection faild.
And
gst-launch-1.0 rtspsrc location=rtsp://127.0.0.1:8554/ds-test ! rtph264depay ! h264parse ! nvv4l2decoder ! nvoverlaysink
doesn’t work as well.
help me, pls.
Please open VLC on x86 PC and try to connect TX2:
rtsp://<_IP_OF_YOUR_TX2_>:8554/ds-test
It faild.
But it works when I changed port from 8554 to 48842.
thx!!! This helps me a lot.
