TX2 carrier board conversion to TX2i - TX2i not booting except into recovery
I have a custom carrier board for the TX2 that I am trying to get working with a TX2i and the TX2i does not boot.
  • Both systems are running their respective jetpack 4.6.4 for the development kit.
    • I have modified it to output the boot logs on UART1 instead of UART0 as per this post as my board has no UART0 output available
  • The TX2i will boot completely fine into recovery but not otherwise
  • I have verified both the TX2 and TX2i on a commercial carrier and they both work fine on it
  • I have verified the TX2 booting and the TX2i not booting using the UART output available on boot
    • The TX2 outputs on both my carrier and the commercial one, the TX2i only on the commercial one
  • I have software control of the PWR_BTN pin, and have set it so that when the TX2i is present, the pin is held high to achieve the auto power on behaviour
  • Both boards reach the CARRIER_PWR_ON state
  • I am using a 12V power rail and the VIN_PWR_BAD pin on the TX2i is high when the module is powered which I understand indicates the power supply is not the issue
Please could you help me solve this, my main questions are:
  • are there any differences to the power up sequence between the TX2 and the TX2i other than the PWR_BTN behaviour?
  • is there anything I can do to investigate boot issues before cboot in the boot flow?
  • is there anything else you think could help with this? as I have run out of ideas for what to test
First of all, how did you flash the device?
Are you flashing it with the right config file?
I was flashing it using the flash.sh script with jetson-tx2i mmcblk0p1 as the arguments, however the issue has been persistent when flashing this way and with our custom yocto based firmware.
I have since managed to find the issue, after leaving it running overnight at some point it entered cboot and output
cb_vic_scrub: VIC Scrub Failure, error 0x6, cmd = 0x1
over uart.
which led me to this post and this post talking about the DRAM ECC scrub failing if the on UART0_RTS and UART1_TX pins are biased on startup.
I was able to resolve the issue by setting disable_staged_scrub=1; in tegra186-mb1-bct-misc-si-l4t-storm.cfg
If this is likely to cause problems in future please let me know, otherwise thank you for your swift response.
Sorry for the late response.
