I was wondering if the TX2 has enough computing power to run a fully autonomous robot? It would be image processing from 4 kinects, a LiDAR system, and using a GPS for positional awareness. All of this needs to happen real time without delay. If it is powerful enough can we step in to the territory of machine learning? Thanks!
Hi BuckGup,
Yes, Jetson TX2 with GPU-accelerated parallel processing is the powerful embedded AI computing platform.
You will need to do more study on your use cases, and we will be loving to support you while developing your product.
