background:We have custom carrier boards,And successfully used the pcie device to transmit data
question:If I need to add another pcie device to the pcie interface, will my hardware connection be the same as the first one?
Do you mean you want to plug one more pcie device and shares the bus with the same device?
yes, Dose it is possible?
Since PCIe is a one-to-one bus, I’m not sure if I understood your question correctly. Do you mean, you want to add a PCIe switch to extend the number of devices you can connect to your custom board slot? If yes, then the answer is yes.
thank you very much
