Hi, we are developing a driver for the AR0231 camera, and whenever we try to capture there is an error on the CSI as follow:
kworker/5:1-115 [005] ...1 916.072361: rtos_queue_peek_from_isr_failed: tstamp:28754818847 queue:0x0b4a3c58
kworker/5:1-115 [005] ...1 916.072369: rtcpu_start: tstamp:28754820987
kworker/5:1-115 [005] ...1 916.072372: rtcpu_vinotify_handle_msg: tstamp:28755525788 tag:CHANSEL_PXL_SOF channel:0x00 frame:229 vi_tstamp:2985721432 data:0x00000001
kworker/5:1-115 [005] ...1 916.072373: rtcpu_vinotify_handle_msg: tstamp:28755525978 tag:ATOMP_FS channel:0x00 frame:229 vi_tstamp:2985721441 data:0x00000000
kworker/5:1-115 [005] ...1 916.072375: rtcpu_vinotify_handle_msg: tstamp:28755528733 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:229 vi_tstamp:2985724526 data:0x08000000
kworker/5:1-115 [005] ...1 916.072376: rtcpu_vinotify_handle_msg: tstamp:28755696880 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:229 vi_tstamp:2985892494 data:0x00000001
kworker/5:1-115 [005] ...1 916.072378: rtcpu_vinotify_handle_msg: tstamp:28755697123 tag:ATOMP_FE channel:0x00 frame:229 vi_tstamp:2985892498 data:0x00000000
Do you know what could be causing the SHORT_FRAME issue? We have tested the sensor register configuration with another system (Evaluation board) and it works properly.
The sensor configuration is 1928x1208@30 RAW12 and 2 MIPI Lanes. Do you foresee any issue with this setup?
Is there a way to debug further this issue?
Thanks for your help in advance.
