TX2 CSI Capture with Jetpack 4.5.1
My bad. I still have that CSI patch applied. The results above are all with that patch:
~/nvidia/nvidia_sdk/JetPack_4.5.1_Linux_JETSON_TX2/Linux_for_Tegra/sources/kernel/nvidia$ git status
On branch l4t/l4t-r32.5
Your branch is up-to-date with 'origin/l4t/l4t-r32.5'.
Changes not staged for commit:
  (use "git add <file>..." to update what will be committed)
  (use "git checkout -- <file>..." to discard changes in working directory)
	modified:   drivers/media/platform/tegra/camera/csi/csi4_fops.c
	modified:   drivers/net/ethernet/nvidia/pcie/tegra_vnet.c
	modified:   drivers/pci/endpoint/functions/pci-epf-tegra-vnet.c
no changes added to commit (use "git add" and/or "git commit -a")
Here is the dmesg output as it stands with the CSI patch applied:
[ 1600.912180] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1600.922635] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000e
[ 1601.133714] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1601.140186] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1601.150271] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000e
[ 1601.361718] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1601.368205] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1601.378089] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000e
[ 1601.605705] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1601.612231] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1601.622663] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000e
[ 1601.631453] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) INTR_STATUS 0x00000008
[ 1601.639307] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERR_INTR_STATUS 0x00000008
[ 1601.849721] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1601.856187] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1601.866786] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000e
[ 1602.077698] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1602.084172] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1602.094596] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000e
[ 1602.305739] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1602.312238] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1602.322709] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000e
[ 1602.541717] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1602.548194] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 1602.558285] nvcsi 150c0000.nvcsi: csi4_stream_check_status (0) ERROR_STATUS2VI_VC0 = 0x0000000e
[ 1602.773717] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 1602.780183] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
There is a occasional anomaly, that I managed to catch above, with (ERR_)INTR_STATUS.
We can see that there are no ECC errors reported, even though the bits are set in the ERROR_STATUS2VI_VC0 register, which I assume is due to the patch masking out those conditions.
I have no more ideas on how to proceed now. Is it worth changing from a driver module to a kernel built-in?
Does nvidia engineering have any suggestions?
I’ve attached two example frames. The top one doesn’t work (720p60) - the bottom one does (720p50)
Screenshot 2021-09-02 112254
There is an obvious difference with the horizontal flyback, but I think there is plenty of time between lines in both cases.
Could you read those REG back to confirm it was masked.
Hi Ratbert,
Any update? Could you read those REG back to confirm it was masked.
