I am trying to debug what’s going wrong while the TX2 is handling an incoming MIPI stream.
With the debugging info I find in Jetson TX2 Camera BringUp - eLinux.org I am able to see the following during the reception:
v4l_id-7828 [000] .... 68.667582: tegra_channel_open: vi-output, ov10640 9-0049
v4l_id-7828 [000] .... 68.669966: tegra_channel_set_power: ov10640 9-0049 : 0x1
v4l_id-7828 [000] .... 68.669977: camera_common_s_power: status : 0x1
v4l_id-7828 [000] .... 68.670038: tegra_channel_set_power: 150c0000.nvcsi--6 : 0x1
v4l_id-7828 [000] .... 68.670042: csi_s_power: enable : 0x1
v4l_id-7828 [002] .... 68.675702: tegra_channel_close: vi-output, ov10640 9-0049
v4l_id-7828 [002] .... 68.675714: tegra_channel_set_power: ov10640 9-0049 : 0x0
v4l_id-7828 [002] .... 68.675725: camera_common_s_power: status : 0x0
v4l_id-7828 [001] .... 68.675829: tegra_channel_set_power: 150c0000.nvcsi--6 : 0x0
v4l_id-7828 [001] .... 68.675835: csi_s_power: enable : 0x0
v4l2-ctl-7837 [002] .... 76.988819: tegra_channel_open: vi-output, ov10640 9-0049
v4l2-ctl-7837 [002] .... 76.989983: tegra_channel_set_power: ov10640 9-0049 : 0x1
v4l2-ctl-7837 [002] .... 76.989994: camera_common_s_power: status : 0x1
v4l2-ctl-7837 [002] .... 76.990057: tegra_channel_set_power: 150c0000.nvcsi--6 : 0x1
v4l2-ctl-7837 [002] .... 76.990060: csi_s_power: enable : 0x1
v4l2-ctl-7837 [002] .... 76.999431: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1080 fmt 20
vi-output, ov10-7838 [000] .... 76.999701: tegra_channel_set_stream: enable : 0x1
vi-output, ov10-7838 [001] .... 77.002156: tegra_channel_set_stream: 150c0000.nvcsi--6 : 0x1
vi-output, ov10-7838 [001] .... 77.002162: csi_s_stream: enable : 0x1
vi-output, ov10-7838 [001] .... 77.002201: tegra_channel_set_stream: ov10640 9-0049 : 0x1
kworker/2:0-24 [002] .... 77.029002: rtos_queue_peek_from_isr_failed: tstamp:2774369496 queue:0x0b4b4500
kworker/2:0-24 [002] .... 77.029006: rtcpu_start: tstamp:2774372588
vi-output, ov10-7838 [001] .... 78.577076: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1080 fmt 20
vi-output, ov10-7838 [001] .... 78.577120: tegra_channel_capture_frame: sof:-549620696288.-266827611008
Note the tegra_channel_capture_frame: sof:-549620696288.-266827611008
The timestamp/argument after the SOF is weird.
In a working scenario, it looks like this:
v4l2-ctl-7157 [002] .... 162.442877: tegra_channel_open: vi-output, ov10640 9-0049
v4l2-ctl-7157 [002] .... 162.444041: tegra_channel_set_power: ov10640 9-0049 : 0x1
v4l2-ctl-7157 [002] .... 162.444053: camera_common_s_power: status : 0x1
v4l2-ctl-7157 [002] .... 162.444132: tegra_channel_set_power: 150c0000.nvcsi--6 : 0x1
v4l2-ctl-7157 [002] .... 162.444135: csi_s_power: enable : 0x1
v4l2-ctl-7157 [002] .... 162.453027: tegra_channel_capture_setup: vnc_id 0 W 1280 H 1080 fmt 20
vi-output, ov10-7158 [000] .... 162.453221: tegra_channel_set_stream: enable : 0x1
vi-output, ov10-7158 [001] .... 162.459202: tegra_channel_set_stream: 150c0000.nvcsi--6 : 0x1
vi-output, ov10-7158 [001] .... 162.459208: csi_s_stream: enable : 0x1
vi-output, ov10-7158 [001] .... 162.459247: tegra_channel_set_stream: ov10640 9-0049 : 0x1
kworker/2:0-24 [002] .... 162.497559: rtos_queue_peek_from_isr_failed: tstamp:5446077303 queue:0x0b4b4500
kworker/2:0-24 [002] .... 162.497565: rtcpu_start: tstamp:5446079353
vi-output, ov10-7158 [001] .... 163.732700: tegra_channel_capture_frame: sof:163.366997691
vi-output, ov10-7158 [001] .... 163.765097: tegra_channel_capture_frame: sof:163.399423195
kworker/2:0-24 [002] .... 163.785658: rtos_queue_peek_from_isr_failed: tstamp:5486077687 queue:0x0b4b4500
kworker/2:0-24 [002] .... 163.785675: rtcpu_vinotify_event: tstamp:5486086151 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:5486085655 data:0x00000001
kworker/2:0-24 [002] .... 163.785684: rtcpu_vinotify_event: tstamp:5486086316 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:5486085659 data:0x00000000
kworker/2:0-24 [002] .... 163.785691: rtcpu_vinotify_event: tstamp:5486093352 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:1 vi_tstamp:5486092974 data:0x08000000
kworker/2:0-24 [002] .... 163.785698: rtcpu_vinotify_event: tstamp:5486742676 tag:CHANSEL_PXL_EOF channel:0x00 frame:1 vi_tstamp:5486741999 data:0x04370002
kworker/2:0-24 [002] .... 163.785705: rtcpu_vinotify_event: tstamp:5486742793 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:5486742025 data:0x00000000
kworker/2:0-24 [002] .... 163.785713: rtcpu_vinotify_event: tstamp:5487099467 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:5487098952 data:0x00000001
kworker/2:0-24 [002] .... 163.785720: rtcpu_vinotify_event: tstamp:5487099629 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:5487098956 data:0x00000000
kworker/2:0-24 [002] .... 163.785727: rtcpu_vinotify_event: tstamp:5487105571 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:2 vi_tstamp:5487105205 data:0x08000000
Any idea what could be causing the system to detect the SOF, but discarding it? The traces are not telling much more useful.
Also, for some reason, in the non working case, it is always doing tegra_channel_capture_setup before tegra_channel_capture_frame, while in the working case it just says capture_frame twice.
Thanks for your reply!
Arnout
