We want to use TX2 with tegra_multimedia_api to decode H264 frame by frame, we get H264 frame data from specific network, and we want to leverage TX2 HW codec to decode this standard H264 frame. we refer 00_video_decode on tegra_multimedia_api, but from this example, it shows me to many parameters that need to get from open a h264 file like below example, and even we set the resolution also crop resolution, it still has other parameters gets from open file.
Does Nvidia team have a example to show me show to use HW codec without open mediafile, I could config these parameters directly like ffmpeg -h264 did?
cout << "Starting decoder capture loop thread" << endl;
// Need to wait for the first Resolution change event, so that
// the decoder knows the stream resolution and can allocate appropriate
// buffers when we call REQBUFS
do
ret = dec->dqEvent(ev, 50000);
if (ret < 0)
if (errno == EAGAIN)
cerr <<
"Timed out waiting for first V4L2_EVENT_RESOLUTION_CHANGE"
<< endl;
else
cerr << "Error in dequeueing decoder event" << endl;
abort(ctx);
break;
while ((ev.type != V4L2_EVENT_RESOLUTION_CHANGE) && !ctx->got_error);
on this example, do you know how do I make sure the queueFrame already decode by hw and we could dequeueFrame to do next process, on this example, it queue all frame and after that, it dequeue and render it.
while I open input_nalu flag with h264 files as input, I can not see the decode result on my screen, but if I disable it, use read_decoder_input_chunk function, it works normal with files input.
anything I miss while open input_nalu with file? I want to double check this function works with file, then re-write it with our data input.
btw I already checked the nalu data, it parses fine and fill data in buffer already.
now I could read nalu data correctly , but I am blocking on qbuffer and dqbuffer, on nonblocking function,
I can deBuffer and get w/o error, so the ret always is 0, on this situation, the code will not check_capture_buffers and do next step, ps: I get the network nalu data continues and update to read_decoder_input_nalu while it calls get nalu data.
do you have any idea about this part?
if (allow_DQ)
ret = ctx.dec->output_plane.dqBuffer(v4l2_output_buf, &output_buffer, NULL, 0);
if (ret < 0)
goto check_capture_buffers;
else
cerr << "Error DQing buffer at output plane" << endl;
abort(&ctx);
break;
if the register is subscribeEvent, yes, I call this function with in decode_proc().
however I can not get V4L2_EVENT_RESOLUTION_CHANGE event to execute query_and_set_capture(), w/o this step, I think the decoder does not work. Do I miss anything?
// Subscribe to Resolution change event
printf("+++ set V4L2_EVENT_RESOLUTION_CHANGE \r\n");
ret = ctx.dec->subscribeEvent(V4L2_EVENT_RESOLUTION_CHANGE, 0, 0);
TEST_ERROR(ret < 0, "Could not subscribe to V4L2_EVENT_RESOLUTION_CHANGE",
cleanup);
Call SetPollInterrupt() and wait for the semaphores.
/* Call for SetPollInterrupt.
Refer V4L2_CID_MPEG_SET_POLL_INTERRUPT */
ctx.dec->SetPollInterrupt();
/* Since buffers have been queued, issue a post to start polling and
then wait here. */
sem_post(&ctx.pollthread_sema);
sem_wait(&ctx.decoderthread_sema);
/* Call for dequeuing an event.
Refer ioctl VIDIOC_DQEVENT */
ret = ctx.dec->dqEvent(ev, 0);
I could decode and show it on screen now, but the display fps is not good, my camera fps is 24fps, and this is the result I got. https://drive.google.com/file/d/1zlSO0HImz40kgTNOBDGejbSLiV-c7pIV/view?usp=sharing
I set display and decode fps to 24, anything I need to take care about?
update info, I found something interesting but I can't find out how to handle it.
my camera output is 25fps, but if I set decode fps is 25, than I will encounter the jitter or stop situation while I watch the screen, but if I set 24fps on decode fps, it's okay on screen but I will get queue buffer issue, the screen will delay to show.
My question is how to get correct setting on it?
my video source output is 24pfs, and I could save it as H264 file and decode/display it with sample 00, but while I use nalu input, the jitter and queue buffer issue is occurred, BTW the display setting is the same.
any suggestion about it?
this is my display setting
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 600mm x 340mm
1920x1080 60.00*+ 59.95 50.00
1680x1050 59.96
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x1024 75.03 60.00
1280x960 60.00
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.01
832x624 75.05
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
720x400 70.04
640x480 75.00 67.06 59.94 59.94
Please configure more buffers in output plane. By default it is 2.
/* Query, Export and Map the output plane buffers so can read
encoded data into the buffers. */
if (ctx.output_plane_mem_type == V4L2_MEMORY_MMAP) {
/* configure decoder output plane for MMAP io-mode.
Refer ioctl VIDIOC_REQBUFS, VIDIOC_QUERYBUF and VIDIOC_EXPBUF */
ret = ctx.dec->output_plane.setupPlane(V4L2_MEMORY_MMAP, 2, true, false);
thanks for that, one more question, how to get decode result output buffer, I saw on dump_dmabuf function, it will sync mem to cpu then write the data to file line by line, Does Nvidia have other example that could sync mem and move data by block directly?
The output of hardware decoder is with hardware alignment, so you need to check pitch,width,height to get valid data. It is hardware limit. If you would like to avoid it, you can convert to RGBA format, which does not have hardware alignment.
