I have a new TX2 board, and I have been experimenting with it using the deepstream-imagedata-multistream python example, and I have some issues:
After running the example code, I noticed that the first 2 saved image files are black image, but they have the bounding boxes saved withing the image file. Example run using the sample_1080p_h264.mp4 video file. All other saved images after that are fine.
Why are the first two images corrupted?
When I used 4 inputs files (based on the sample_1080p_h264.mp4 video), the tiled video display freezes several times (just for a short moment).
Why does the tiled display freezes?
Is there a limit when using TX2 with 4 video sources (video resolution and FPS )?
• DeepStream Version
• TensorRT Version
The code was not changed and to run it I used:
$ python3 deepstream_imagedata-multistream.py file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_1080p_h264.mp4 frames
The program run without any errors.
While checking the saved image files in ‘frames’ directory, I noticed that the first 2 image file are corrupted: the frame image is black but the bounding boxes are available:
I run the program several times and the result was always the same ( 2 first saved files are corrupted).
Please inform me if this is a bug or system limitation for saving the first 2 frames?
