I have flashed jetpack 3.3 in tx2 and have external ssd made as boot drive. after sudo get update my desktop shows up blank.
[ 10.280003] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 10.282105] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 10.282137] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 10.283207] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
[ 10.351347] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work mailbox command 5
[ 10.351363] xhci-tegra 3530000.xhci: tegra_xhci_mbox_work ignore firmware MBOX_CMD_DEC_SSPI_CLOCK request
[ 10.608596] Bridge firewalling registered
[ 10.709286] ip_tables: © 2000-2006 Netfilter Core Team
[ 11.052986] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[ 11.108091] tegradc 15210000.nvdisplay: unblank
[ 11.154695] CPU1: shutdown
[ 11.157418] psci: CPU1 killed.
[ 11.186999] CPU2: shutdown
[ 11.190403] psci: CPU2 killed.
[ 12.144952] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.153991] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.215552] fuse init (API version 7.23)
[ 14.621271] IPVS: Creating netns size=1424 id=2
[ 14.835129] tegradc 15210000.nvdisplay: blank - powerdown
[ 14.893286] PD DISP2 index4 DOWN
[ 14.980816] tegradc 15210000.nvdisplay: unblank
[ 15.828293] IPVS: Creating netns size=1424 id=3
[ 16.274539] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 17.533255] logitech-djreceiver 0003:046D:C52B.0008: hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3530000.xhci-2/input2
[ 17.665507] input: Logitech M215 2nd Gen as /devices/3530000.xhci/usb1/1-2/1-2:1.2/0003:046D:C52B.0008/0003:046D:401B.0009/input/input6
[ 17.678637] logitech-hidpp-device 0003:046D:401B.0009: input,hidraw1: USB HID v1.11 Mouse [Logitech M215 2nd Gen] on usb-3530000.xhci-2:1
[ 17.697558] input: Logitech K330 as /devices/3530000.xhci/usb1/1-2/1-2:1.2/0003:046D:C52B.0008/0003:046D:4016.000A/input/input7
[ 17.712460] logitech-hidpp-device 0003:046D:4016.000A: input,hidraw2: USB HID v1.11 Keyboard [Logitech K330] on usb-3530000.xhci-2:2
[ 733.210176] IPVS: Creating netns size=1424 id=4
