TX2 Dev-kit board Ethernet Controller
I was wondering if someone would be able to share which Ethernet controller is used on the TX2 Dev Kit.
Also, is the Ethernet controller built-in on TX2 or is it provided by the Dev-kit board?
Thank You,
Shivam
Hi, please refer to this topic: [url]Datasheet for Jetson TX2 Ethernet controller - Jetson TX2 - NVIDIA Developer Forums
We can not reveal 3rd-party controller IP info. The PHY on carrier board is BCM54610C1IMLG.
Thank you for the reply. Would you be able to share if the controller is built-in with TX2 or is it part of the Dev-kit carrier board?
Thank you.
Shivam
The controller is build-in, and the PHY is on carrier board.
