I tried
./source_sync.sh -k tegra-l4t-r28.2.2
and
./source_sync.sh -k tegra-l4t-r28.2.1
on TX2 and TX2i, but I cannot get my compiled versions to list anything for
lspci
When I freshly install the Jetpack and flash the board, it finds my ethernet card in the 4x slot.
If I compare the working and non-working versions with
dtc -I fs /sys/firmware/devicetree/base >> thisdts
The results look pretty much the same.
pci@1,0 {
reg = <0x800 0x0 0x0 0x0 0x0>;
assigned-addresses = <0x82000800 0x0 0x10000000 0x0 0x1000>;
device_type = "pci";
ranges;
status = "okay";
#address-cells = <0x3>;
#size-cells = <0x2>;
nvidia,afi-ctl-offset
nvidia,num-lanes = <0x4>;
pci@2,0 {
reg = <0x1000 0x0 0x0 0x0 0x0>;
assigned-addresses = <0x82001000 0x0 0x10001000 0x0 0x1000>;
ranges;
status = "disabled";
nvidia,afi-ctl-offset = <0x118>;
nvidia,num-lanes = <0x0>;
pci@3,0 {
reg = <0x1800 0x0 0x0 0x0 0x0>;
assigned-addresses = <0x82001800 0x0 0x10004000 0x0 0x1000>;
ranges;
status = "okay";
nvidia,afi-ctl-offset = <0x19c>;
nvidia,num-lanes = <0x1>;
Is there some step that applies the p2597 BSP that I am missing in the build process?
I’m using
NVIDIA Tegra Linux Driver Package
Development Guide
28.2 Release
Thanks!!!
Correction
I tried
and
I just used ./source_sync.sh and pasted the tags in when it asked for them
Thanks!!
Could you check the kernel name by uname -a
This is what your tegra-l4t-r28.2.1 git tag looks like:
ubuntu@tegra-ubuntu:~$ uname -a
Linux tegra-ubuntu 4.4.38+ #4 SMP PREEMPT Tue Mar 26 13:53:55 MST 2019 aarch64 aarch64 aarch64 GNU/Linux
/etc/nv_tegra_release
R28 (release), REVISION: 2.1, GCID: 11272647, BOARD: t186ref, EABI: aarch64, DATE: Thu May 17 07:29:06 UTC 2018
Makefile:
VERSION = 4
PATCHLEVEL = 4
SUBLEVEL = 38
EXTRAVERSION =
NAME = Blurry Fish Butt
jetson-tx2.conf
p2771-0000-devkit.conf: configuration for T186-A02 te770d-UCM2 Silicon
BPFDTB_FILE=tegra186-a02-bpmp-quill-p3310-1000-a00-00-te770d-ucm2.dtb;
source “${LDK_DIR}/p2771-0000.conf.common”;
jetson-tx2i.conf
p2771-3489-ucm1.conf: configuration for T186-A02 ta795sa Silicon ucm1 profile
BPFDTB_FILE=tegra186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1.dtb;
SYSBOOTFILE=p2771-0000/extlinux.conf;
EMMC_BCT=P3489_A00_8GB_Samsung_8GB_lpddr4_204Mhz_P134_A02_ECC_en_l4t.cfg
DTB_FILE=tegra186-quill-p3489-1000-a00-00-ucm1.dtb;
TBCDTB_FILE=tegra186-quill-p3489-1000-a00-00-ucm1.dtb;
PROD_CONFIG=“tegra186-mb1-bct-prod-storm-p3489-1000-a00.cfg”;
PINMUX_CONFIG=“tegra186-mb1-bct-pinmux-quill-p3489-1000-a00.cfg”;
PMIC_CONFIG=“tegra186-mb1-bct-pmic-quill-p3489-1000-a00.cfg”;
PMC_CONFIG=“tegra186-mb1-bct-pad-quill-p3489-1000-a00.cfg”;
BOOTROM_CONFIG=“tegra186-mb1-bct-bootrom-quill-p3489-1000-a00.cfg”;
Are you cross-compiling the kernel on an x86 PC and then reflashing with flash.sh, or compiling on Jetson itself?
After compilation, which files are you copying where to install the new kernel; did you also install the matching DTS and module files?
Which compiler are you using?
After you boot Jetson with the new kernel, what PCIe-related messages are seen in the kernel log? Run “dmesg” to see the full log.
I’m using the instructions that came with 28.2.2 →
NVIDIA_Tegra_Linux_Driver_Package/nvl4t_docs/index.html#page/Tegra%2520Linux%2520Driver%2520Package%2520Development%2520Guide%2Fkernel_custom.html
Kernel Customization instructions from the
Development Guide
28.2 Release
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j8
sudo cp /home/alphi/TX2/64_TX2/Linux_for_Tegra/kernel-out/kernel/arch/arm64/boot/Image /home/alphi/TX2/64_TX2/Linux_for_Tegra/kernel/Image
sudo cp -r /home/alphi/TX2/64_TX2/Linux_for_Tegra/kernel-out/kernel/arch/arm64/boot/dts/* /home/alphi/TX2/64_TX2/Linux_for_Tegra/kernel/dtb/
sudo ./apply_binaries.sh
sudo ./flash.sh jetson-tx2i mmcblk0p1
or
sudo ./flash.sh jetson-tx2 mmcblk0p1
I used the precompiled toolchain from the download directory.
ubuntu@tegra-ubuntu:~$ dmesg|grep pci
[ 0.143022] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.143751] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.267159] iommu: Adding device 10003000.pcie-controller to group 50
ubuntu@tegra-ubuntu:~$ lspci
The dtb appears to update. I moved the HDMI and fixed the USB for my carrier. When I couldn’t get the PCIe to work, I went back to the dev kit and noticed that it never worked there unless I used the factory image to flash.
Setting the LOCALVERSION by below command while you build the kernel. Please do a clean build.
export LOCALVERSION=-tegra
