TX2 DS4.0 loadeight
I found the code “removed 5 int32 bytes” in loadweight file, Why it removed 5 bytes for yolov3? If I use yolov3-spp newwork ,what the value should be?
std::vector<float> loadWeights(const std::string weightsFilePath, const std::string& networkType)
    assert(fileExists(weightsFilePath));
    std::cout << "Loading pre-trained weights..." << std::endl;
    std::ifstream file(weightsFilePath, std::ios_base::binary);
    assert(file.good());
    std::string line;
    if (networkType == "yolov2")
        // Remove 4 int32 bytes of data from the stream belonging to the header
        file.ignore(4 * 4);
    else if ((networkType == "yolov3") || (networkType == "yolov3-tiny")
             || (networkType == "yolov2-tiny"))
        // Remove 5 int32 bytes of data from the stream belonging to the header
        file.ignore(4 * 5);
    else
        std::cout << "Invalid network type" << std::endl;
        assert(0);
I have known the reson ,it’s due to the file header value.
But I used yolo-spp3 to do test,the precision detection decreased a lot.
So confused for me,It looks like related with spp module parsing ,because this is the only different point compared with yolov3. Do you know the possible reson? or give me a reference case of yolo-spp?
SPP
[maxpool]
stride=1
size=5
[route]
layers=-2
[maxpool]
stride=1
size=9
[route]
layers=-4
[maxpool]
stride=1
size=13
[route]
layers=-1,-3,-5,-6
End SPP
.cfg file
[net]
2.# Testing
3.batch=1
4.subdivisions=1
5.# Training
6.# batch=64
7.# subdivisions=16
8.width=608
9.height=608
10.channels=3
11.momentum=0.9
12.decay=0.0005
13.angle=0
14.saturation = 1.5
15.exposure = 1.5
16.hue=.1
17.
18.learning_rate=0.001
19.burn_in=1000
20.max_batches = 120200
21.policy=steps
22.steps=70000,100000
23.scales=.1,.1
24.
25.[convolutional]
26.batch_normalize=1
27.filters=32
28.size=3
29.stride=1
30.pad=1
31.activation=leaky
32.
33.# Downsample
34.
35.[convolutional]
36.batch_normalize=1
37.filters=64
38.size=3
39.stride=2
40.pad=1
41.activation=leaky
42.
43.[convolutional]
44.batch_normalize=1
45.filters=32
46.size=1
47.stride=1
48.pad=1
49.activation=leaky
50.
51.[convolutional]
52.batch_normalize=1
53.filters=64
54.size=3
55.stride=1
56.pad=1
57.activation=leaky
58.
59.[shortcut]
60.from=-3
61.activation=linear
62.
63.# Downsample
64.
65.[convolutional]
66.batch_normalize=1
67.filters=128
68.size=3
69.stride=2
70.pad=1
71.activation=leaky
72.
73.[convolutional]
74.batch_normalize=1
75.filters=64
76.size=1
77.stride=1
78.pad=1
79.activation=leaky
80.
81.[convolutional]
82.batch_normalize=1
83.filters=128
84.size=3
85.stride=1
86.pad=1
87.activation=leaky
88.
89.[shortcut]
90.from=-3
91.activation=linear
92.
93.[convolutional]
94.batch_normalize=1
95.filters=64
96.size=1
97.stride=1
98.pad=1
99.activation=leaky
100.
101.[convolutional]
102.batch_normalize=1
103.filters=128
104.size=3
105.stride=1
106.pad=1
107.activation=leaky
108.
109.[shortcut]
110.from=-3
111.activation=linear
112.
113.# Downsample
114.
115.[convolutional]
116.batch_normalize=1
117.filters=256
118.size=3
119.stride=2
120.pad=1
121.activation=leaky
122.
123.[convolutional]
124.batch_normalize=1
125.filters=128
126.size=1
127.stride=1
128.pad=1
129.activation=leaky
130.
131.[convolutional]
132.batch_normalize=1
133.filters=256
134.size=3
135.stride=1
136.pad=1
137.activation=leaky
138.
139.[shortcut]
140.from=-3
141.activation=linear
142.
143.[convolutional]
144.batch_normalize=1
145.filters=128
146.size=1
147.stride=1
148.pad=1
149.activation=leaky
150.
151.[convolutional]
152.batch_normalize=1
153.filters=256
154.size=3
155.stride=1
156.pad=1
157.activation=leaky
158.
159.[shortcut]
160.from=-3
161.activation=linear
162.
163.[convolutional]
164.batch_normalize=1
165.filters=128
166.size=1
167.stride=1
168.pad=1
169.activation=leaky
170.
171.[convolutional]
172.batch_normalize=1
173.filters=256
174.size=3
175.stride=1
176.pad=1
177.activation=leaky
178.
179.[shortcut]
180.from=-3
181.activation=linear
182.
183.[convolutional]
184.batch_normalize=1
185.filters=128
186.size=1
187.stride=1
188.pad=1
189.activation=leaky
190.
191.[convolutional]
192.batch_normalize=1
193.filters=256
194.size=3
195.stride=1
196.pad=1
197.activation=leaky
198.
199.[shortcut]
200.from=-3
201.activation=linear
202.
203.
204.[convolutional]
205.batch_normalize=1
206.filters=128
207.size=1
208.stride=1
209.pad=1
210.activation=leaky
211.
212.[convolutional]
213.batch_normalize=1
214.filters=256
215.size=3
216.stride=1
217.pad=1
218.activation=leaky
219.
220.[shortcut]
221.from=-3
222.activation=linear
223.
224.[convolutional]
225.batch_normalize=1
226.filters=128
227.size=1
228.stride=1
229.pad=1
230.activation=leaky
231.
232.[convolutional]
233.batch_normalize=1
234.filters=256
235.size=3
236.stride=1
237.pad=1
238.activation=leaky
239.
240.[shortcut]
241.from=-3
242.activation=linear
243.
244.[convolutional]
245.batch_normalize=1
246.filters=128
247.size=1
248.stride=1
249.pad=1
250.activation=leaky
251.
252.[convolutional]
253.batch_normalize=1
254.filters=256
255.size=3
256.stride=1
257.pad=1
258.activation=leaky
259.
260.[shortcut]
261.from=-3
262.activation=linear
263.
264.[convolutional]
265.batch_normalize=1
266.filters=128
267.size=1
268.stride=1
269.pad=1
270.activation=leaky
271.
272.[convolutional]
273.batch_normalize=1
274.filters=256
275.size=3
276.stride=1
277.pad=1
278.activation=leaky
279.
280.[shortcut]
281.from=-3
282.activation=linear
283.
284.# Downsample
285.
286.[convolutional]
287.batch_normalize=1
288.filters=512
289.size=3
290.stride=2
291.pad=1
292.activation=leaky
293.
294.[convolutional]
295.batch_normalize=1
296.filters=256
297.size=1
298.stride=1
299.pad=1
300.activation=leaky
301.
302.[convolutional]
303.batch_normalize=1
304.filters=512
305.size=3
306.stride=1
307.pad=1
308.activation=leaky
309.
310.[shortcut]
311.from=-3
312.activation=linear
313.
314.
315.[convolutional]
316.batch_normalize=1
317.filters=256
318.size=1
319.stride=1
320.pad=1
321.activation=leaky
322.
323.[convolutional]
324.batch_normalize=1
325.filters=512
326.size=3
327.stride=1
328.pad=1
329.activation=leaky
330.
331.[shortcut]
332.from=-3
333.activation=linear
334.
335.
336.[convolutional]
337.batch_normalize=1
338.filters=256
339.size=1
340.stride=1
341.pad=1
342.activation=leaky
343.
344.[convolutional]
345.batch_normalize=1
346.filters=512
347.size=3
348.stride=1
349.pad=1
350.activation=leaky
351.
352.[shortcut]
353.from=-3
354.activation=linear
355.
356.
357.[convolutional]
358.batch_normalize=1
359.filters=256
360.size=1
361.stride=1
362.pad=1
363.activation=leaky
364.
365.[convolutional]
366.batch_normalize=1
367.filters=512
368.size=3
369.stride=1
370.pad=1
371.activation=leaky
372.
373.[shortcut]
374.from=-3
375.activation=linear
376.
377.[convolutional]
378.batch_normalize=1
379.filters=256
380.size=1
381.stride=1
382.pad=1
383.activation=leaky
384.
385.[convolutional]
386.batch_normalize=1
387.filters=512
388.size=3
389.stride=1
390.pad=1
391.activation=leaky
392.
393.[shortcut]
394.from=-3
395.activation=linear
396.
397.
398.[convolutional]
399.batch_normalize=1
400.filters=256
401.size=1
402.stride=1
403.pad=1
404.activation=leaky
405.
406.[convolutional]
407.batch_normalize=1
408.filters=512
409.size=3
410.stride=1
411.pad=1
412.activation=leaky
413.
414.[shortcut]
415.from=-3
416.activation=linear
417.
418.
419.[convolutional]
420.batch_normalize=1
421.filters=256
422.size=1
423.stride=1
424.pad=1
425.activation=leaky
426.
427.[convolutional]
428.batch_normalize=1
429.filters=512
430.size=3
431.stride=1
432.pad=1
433.activation=leaky
434.
435.[shortcut]
436.from=-3
437.activation=linear
438.
439.[convolutional]
440.batch_normalize=1
441.filters=256
442.size=1
443.stride=1
444.pad=1
445.activation=leaky
446.
447.[convolutional]
448.batch_normalize=1
449.filters=512
450.size=3
451.stride=1
452.pad=1
453.activation=leaky
454.
455.[shortcut]
456.from=-3
457.activation=linear
458.
459.# Downsample
460.
461.[convolutional]
462.batch_normalize=1
463.filters=1024
464.size=3
465.stride=2
466.pad=1
467.activation=leaky
468.
469.[convolutional]
470.batch_normalize=1
471.filters=512
472.size=1
473.stride=1
474.pad=1
475.activation=leaky
476.
477.[convolutional]
478.batch_normalize=1
479.filters=1024
480.size=3
481.stride=1
482.pad=1
483.activation=leaky
484.
485.[shortcut]
486.from=-3
487.activation=linear
488.
489.[convolutional]
490.batch_normalize=1
491.filters=512
492.size=1
493.stride=1
494.pad=1
495.activation=leaky
496.
497.[convolutional]
498.batch_normalize=1
499.filters=1024
500.size=3
501.stride=1
502.pad=1
503.activation=leaky
504.
505.[shortcut]
506.from=-3
507.activation=linear
508.
509.[convolutional]
510.batch_normalize=1
511.filters=512
512.size=1
513.stride=1
514.pad=1
515.activation=leaky
516.
517.[convolutional]
518.batch_normalize=1
519.filters=1024
520.size=3
521.stride=1
522.pad=1
523.activation=leaky
524.
525.[shortcut]
526.from=-3
527.activation=linear
528.
529.[convolutional]
530.batch_normalize=1
531.filters=512
532.size=1
533.stride=1
534.pad=1
535.activation=leaky
536.
537.[convolutional]
538.batch_normalize=1
539.filters=1024
540.size=3
541.stride=1
542.pad=1
543.activation=leaky
544.
545.[shortcut]
546.from=-3
547.activation=linear
548.
549.######################
550.
551.[convolutional]
552.batch_normalize=1
553.filters=512
554.size=1
555.stride=1
556.pad=1
557.activation=leaky
558.
559.[convolutional]
560.batch_normalize=1
561.size=3
562.stride=1
563.pad=1
564.filters=1024
565.activation=leaky
566.
567.[convolutional]
568.batch_normalize=1
569.filters=512
570.size=1
571.stride=1
572.pad=1
573.activation=leaky
574.
575.### SPP ###
576.[maxpool]
577.stride=1
578.size=5
579.
580.[route]
581.layers=-2
582.
583.[maxpool]
584.stride=1
585.size=9
586.
587.[route]
588.layers=-4
589.
590.[maxpool]
591.stride=1
592.size=13
593.
594.[route]
595.layers=-1,-3,-5,-6
596.
597.### End SPP ###
598.
599.[convolutional]
600.batch_normalize=1
601.filters=512
602.size=1
603.stride=1
604.pad=1
605.activation=leaky
606.
607.
608.[convolutional]
609.batch_normalize=1
610.size=3
611.stride=1
612.pad=1
613.filters=1024
614.activation=leaky
615.
616.[convolutional]
617.batch_normalize=1
618.filters=512
619.size=1
620.stride=1
621.pad=1
622.activation=leaky
623.
624.[convolutional]
625.batch_normalize=1
626.size=3
627.stride=1
628.pad=1
629.filters=1024
630.activation=leaky
631.
632.
633.[convolutional]
634.size=1
635.stride=1
636.pad=1
637.filters=45
638.activation=linear
639.
640.
641.[yolo]
642.mask = 6,7,8
643.anchors = 10,13,  16,30,  33,23,  30,61,  62,45,  59,119,  116,90,  156,198,  373,326
644.classes=10
645.num=9
646.jitter=.3
647.ignore_thresh = .7
648.truth_thresh = 1
649.random=1
650.
651.
652.[route]
653.layers = -4
654.
655.[convolutional]
656.batch_normalize=1
657.filters=256
658.size=1
659.stride=1
660.pad=1
661.activation=leaky
662.
663.[upsample]
664.stride=2
665.
666.[route]
667.layers = -1, 61
668.
669.
670.
671.[convolutional]
672.batch_normalize=1
673.filters=256
674.size=1
675.stride=1
676.pad=1
677.activation=leaky
678.
679.[convolutional]
680.batch_normalize=1
681.size=3
682.stride=1
683.pad=1
684.filters=512
685.activation=leaky
686.
687.### SPP ###
688.[maxpool]
689.stride=1
690.size=5
691.
692.[route]
693.layers=-2
694.
695.[maxpool]
696.stride=1
697.size=9
698.
699.[route]
700.layers=-4
701.
702.[maxpool]
703.stride=1
704.size=13
705.
706.[route]
707.layers=-1,-3,-5,-6
708.
709.### End SPP ###
710.
711.
712.[convolutional]
713.batch_normalize=1
714.filters=256
715.size=1
716.stride=1
717.pad=1
718.activation=leaky
719.
720.[convolutional]
721.batch_normalize=1
722.size=3
723.stride=1
724.pad=1
725.filters=512
726.activation=leaky
727.
728.[convolutional]
729.batch_normalize=1
730.filters=256
731.size=1
732.stride=1
733.pad=1
734.activation=leaky
735.
736.[convolutional]
737.batch_normalize=1
738.size=3
739.stride=1
740.pad=1
741.filters=512
742.activation=leaky
743.
744.[convolutional]
745.size=1
746.stride=1
747.pad=1
748.filters=45
749.activation=linear
750.
751.
752.[yolo]
753.mask = 3,4,5
754.anchors = 10,13,  16,30,  33,23,  30,61,  62,45,  59,119,  116,90,  156,198,  373,326
755.classes=10
756.num=9
757.jitter=.3
758.ignore_thresh = .7
759.truth_thresh = 1
760.random=1
761.
762.
763.
764.[route]
765.layers = -4
766.
767.[convolutional]
768.batch_normalize=1
769.filters=128
770.size=1
771.stride=1
772.pad=1
773.activation=leaky
774.
775.[upsample]
776.stride=2
777.
778.[route]
779.layers = -1, 36
780.
781.
782.
783.[convolutional]
784.batch_normalize=1
785.filters=128
786.size=1
787.stride=1
788.pad=1
789.activation=leaky
790.
791.[convolutional]
792.batch_normalize=1
793.size=3
794.stride=1
795.pad=1
796.filters=256
797.activation=leaky
798.
799.[convolutional]
800.batch_normalize=1
801.filters=128
802.size=1
803.stride=1
804.pad=1
805.activation=leaky
806.
807.### SPP ###
808.[maxpool]
809.stride=1
810.size=5
811.
812.[route]
813.layers=-2
814.
815.[maxpool]
816.stride=1
817.size=9
818.
819.[route]
820.layers=-4
821.
822.[maxpool]
823.stride=1
824.size=13
825.
826.[route]
827.layers=-1,-3,-5,-6
828.
829.### End SPP ###
830.
831.[convolutional]
832.batch_normalize=1
833.size=3
834.stride=1
835.pad=1
836.filters=256
837.activation=leaky
838.
839.[convolutional]
840.batch_normalize=1
841.filters=128
842.size=1
843.stride=1
844.pad=1
845.activation=leaky
846.
847.[convolutional]
848.batch_normalize=1
849.size=3
850.stride=1
851.pad=1
852.filters=256
853.activation=leaky
854.
855.[convolutional]
856.size=1
857.stride=1
858.pad=1
859.filters=45
860.activation=linear
861.
862.
863.[yolo]
864.mask = 0,1,2
865.anchors = 10,13,  16,30,  33,23,  30,61,  62,45,  59,119,  116,90,  156,198,  373,326
866.classes=10
867.num=9
868.jitter=.3
869.ignore_thresh = .7
870.truth_thresh = 1
871.random=1
The removal is for the header data.
Sorry that the yolo-spp3 is not in our supported model list yet.
It’s recommended to check the correct header size of the model and apply the corresponding update first.
