I had a DTS/DTB issue with the USB2.0 on a custom PCB with TX2. See this post:
https://devtalk.nvidia.com/default/topic/1028223/jetson-tx2/tx2-usb-not-work/post/5277808/#5277808
I am also having an issue with the PCIe connected to a Xilinx Artix 7. I developed my FPGA code using the Xilinx AC701 connected to the TX2 carrier board and that prototype system works well. However the custom PCB with TX2 socketed and the Artix 7 placed on the board does not work. The PCIe does not show up in the lspci and the dmesg shows:
dmesg | grep pcie
[ 0.142409] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.143141] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.265588] iommu: Adding device 10003000.pcie-controller to group 50
[ 6.111281] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 6.122903] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 6.132412] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 6.145123] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 6.594197] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.262219] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.697787] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.724253] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[ 8.140188] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.554212] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.970217] tegra-pcie 10003000.pcie-controller: link 2 down, retrying
[ 8.978790] tegra-pcie 10003000.pcie-controller: link 2 down, ignoring
[ 8.985878] tegra-pcie 10003000.pcie-controller: PCIE: no end points detected
[ 8.993274] tegra-pcie 10003000.pcie-controller: PCIE: Disable power rails
Inspection inside the FPGA shows that the TX2 is not providing the PCIe reference clock on the custom PCB. I am wondering if there is another device tree issue with the TX2.
