Hi:
We want to dynamicly chang spi1 spi@3210000 to x2 mode to increase data rate. In x2 mode, data is transmitted or received on both miso and mosi lines.
Spi1 is initialized as normal x1 mode and it works fine. After x1 mode transfer, i use the code below to initiate one x2 mode transmit, mosi line transmitted the even bits correctly, but miso line generated no waveform.
I want to known if this kind of operation is workable? or what else parameters i need to config?
platform:TX2 JP32.6.1 custom board
pSpiDev->max_speed_hz = 25 * 1000 * 1000;
pSpiDev->mode |= SPI_TX_DUAL;
ec = spi_setup(pSpiDev);
struct spi_transfer tansfer[1];
memset(tansfer, 0, sizeof(tansfer));
tansfer[0].tx_buf = pTxBuf;
tansfer[0].rx_buf = NULL;
tansfer[0].len = 16;
tansfer[0].cs_change = 0;
tansfer[0].tx_nbits = SPI_NBITS_DUAL;
ec = spi_sync_transfer(pSpiDev, tansfer, ARRAY_SIZE(tansfer));
