I have a performance issue with Ethernet on a TX2.
I have a custom carrier card on which a Marvell 7-port GbE switch is installed. This is directly connected to the TX2 via 10nF/50V AC coupling capacitors.
The routing from the Jetson to the switch seems correct: differential pairs in controlled impedances @ 100Ohm, track lengths < 30mm.
We do not use any of the led ACK signals.
The negotiation is done correctly between the TX2 and the switch:
root@tegra-ubuntu:/home/nvidia# dmesg |grep eth
[ 3.396759] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b c5 44 84
[ 3.432089] usbcore: registered new interface driver cdc_ether
[ 8.175803] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.024088] using random self ethernet address
[ 10.044435] using random host ethernet address
[ 10.503465] using random self ethernet address
[ 10.521289] using random host ethernet address
[ 11.442465] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control off
[ 11.464860] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.493700] eqos 2490000.ether_qos: EQOS ISO BW 81920 reservation failed with 0
The link seems stable and I have no apparent disconnection or error.
eth0 Link encap:Ethernet HWaddr 00:04:4b:c5:44:84
inet addr:192.168.42.49 Bcast:192.168.42.255 Mask:255.255.255.0
inet6 addr: fe80::204:4bff:fec5:4484/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:187911 errors:0 dropped:0 overruns:0 frame:0
TX packets:41867 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:210992912 (210.9 MB) TX bytes:2150358443 (2.1 GB)
Interrupt:42
root@tegra-ubuntu:/home/nvidia# ethtool eth0
Settings for eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Supports Wake-on: ug
Wake-on: g
Link detected: yes
But when I perform a speed test, I am capped at 100~200Mbits/s in RX, while in TX I am very close to Gbits/s (this one is my best)
root@tegra-ubuntu:/home/nvidia# iperf -c 192.168.42.40 -r
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
Client connecting to 192.168.42.40, TCP port 5001
TCP window size: 280 KByte (default)
[ 5] local 192.168.42.49 port 41120 connected with 192.168.42.40 port 5001
[ ID] Interval Transfer Bandwidth
[ 5] 0.0-10.0 sec 1.00 GBytes 861 Mbits/sec
[ 4] local 192.168.42.49 port 5001 connected with 192.168.42.40 port 33848
[ 4] 0.0-10.0 sec 246 MBytes 207 Mbits/sec
(I’ve been doing tests for quite some time)
The test topology is as follows:
TX2 <-> Marvell switch <-> PC
If I do my tests with the following topology, I have no worries:
PC <-> Marvell switch <-> PC
I was confronted with a first sleight of hand regarding the activation of USB on a Custom card (dtb modification), and I wonder if the same kind of thing is possible in the case of Ethernet.
The only thing that could put me on the hint is the following trace:
But I have no idea what this is about, “BW” may be related to BandWidth…
The Marvell switch is known and has been used in other design without issues.
Thank you for your help,
Thomas.
