Hi all,
our carrier board has fan, but the thermal manage incorrect
now when i run “sudo ./jetson_clocks.sh” and find cpu temperature rise(read in psensor)
but the “/sys/kernel/debug/tegra_fan/cur_pwm” value and fan rpm reduce
619824701,
Which release are you using ? Does the fan start to spin after you run jetson clocks?
Is this issue be observed on devkit?
Hi WayneWWW
hardware issue,it is ok now! thanks
