When i use sdkmanager, I find this error in Jetson OS image:
18:12:29 INFO : File System and OS : [ Disk Avail:9.89 GB ]
18:12:29 INFO : File System and OS : Using GenericInstaller to Install NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP
18:12:29 INFO : File System and OS : NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP include 1 package
18:12:29 INFO : File System and OS : change working directory to /media/greepex/4E9AEFD29AEFB49D/Homework/ICRA_AI_Challenge/Jetson4_2_1/SDK/JetPack_4.3_Linux_P3310/Linux_for_Tegra/rootfs/
18:12:29 INFO : File System and OS : [ Package PreInstall Started ]
18:12:29 INFO : File System and OS : current working directory is /media/greepex/4E9AEFD29AEFB49D/Homework/ICRA_AI_Challenge/Jetson4_2_1/SDK/JetPack_4.3_Linux_P3310/Linux_for_Tegra/rootfs
18:12:29 INFO : File System and OS : exec_command: sudo apt-get install -y qemu-user-static
18:12:29 INFO : File System and OS : Reading package lists...
18:12:29 INFO : File System and OS : Building dependency tree...
18:12:29 INFO : File System and OS : Reading state information...
18:12:29 INFO : File System and OS : qemu-user-static is already the newest version (1:2.5+dfsg-5ubuntu10.42).
18:12:29 INFO : File System and OS : The following packages were automatically installed and are no longer required:
18:12:29 INFO : File System and OS : libblas-common libgfortran3 libopenblas-base
18:12:29 INFO : File System and OS : Use 'sudo apt autoremove' to remove them.
18:12:29 INFO : File System and OS : 0 upgraded, 0 newly installed, 0 to remove and 616 not upgraded.
18:12:29 INFO : File System and OS : [ Package PreInstall Finished Successfully ]
18:12:29 INFO : File System and OS : [ Package Install Started ]
18:12:29 INFO : File System and OS : exec_command [host]:
18:12:29 INFO : File System and OS : **********************
18:12:29 INFO : File System and OS : #!/bin/bash
18:12:29 INFO : File System and OS : set -e
18:12:29 INFO : File System and OS : sudo tar xpf /media/greepex/4E9AEFD29AEFB49D/Homework/ICRA_AI_Challenge/Jetson4_3/Tegra_Linux_Sample-Root-Filesystem_R32.3.1_aarch64.tbz2
18:12:29 INFO : File System and OS : cd ..
18:12:29 INFO : File System and OS : sudo ./apply_binaries.sh
18:12:29 INFO : File System and OS : sudo mkdir -p rootfs/opt/nvidia/deb_repos
18:12:29 INFO : File System and OS : exec_command: /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP.sh
18:15:00 INFO : File System and OS : Using rootfs directory of: /media/greepex/4E9AEFD29AEFB49D/Homework/ICRA_AI_Challenge/Jetson4_2_1/SDK/JetPack_4.3_Linux_P3310/Linux_for_Tegra/rootfs
18:15:00 INFO : File System and OS : ||||||||||||||||||||||| ERROR |||||||||||||||||||||||
18:15:00 INFO : File System and OS : -----------------------------------------------------
18:15:00 INFO : File System and OS : 1. The root filesystem, provided with this package,
18:15:00 INFO : File System and OS : has to be extracted to this directory:
18:15:00 INFO : File System and OS : /media/greepex/4E9AEFD29AEFB49D/Homework/ICRA_AI_Challenge/Jetson4_2_1/SDK/JetPack_4.3_Linux_P3310/Linux_for_Tegra/rootfs
18:15:00 INFO : File System and OS : 2. The root filesystem, provided with this package,
18:15:00 INFO : File System and OS : has to be extracted with 'sudo' to this directory:
18:15:00 INFO : File System and OS : Consult the Development Guide for instructions on
18:15:00 INFO : File System and OS : extracting and flashing your device.
18:15:00 INFO : File System and OS : |||||||||||||||||||||||||||||||||||||||||||||||||||||
18:15:00 INFO : File System and OS : exit status 1
18:15:00 INFO : File System and OS : [ Package Install Finished with Error ]
18:15:00 INFO : File System and OS : [ 1.02 MB used. Disk Avail: 9.89 GB ]
18:15:00 INFO : File System and OS : [ NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP Install took 2m32s ]
18:15:00 ERROR : File System and OS : Run commands failed at step Install: command /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP.sh finished with error
18:15:00 ERROR : File System and OS : command terminated with error
18:15:00 ERROR : File System and OS : install 'File System and OS' failure, command < cd '/media/greepex/4E9AEFD29AEFB49D/Homework/ICRA_AI_Challenge/Jetson4_2_1/SDK/JetPack_4.3_Linux_P3310' ; '/opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter' -a='install' -c='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' -i='NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP' -v='32.3' -l='/media/greepex/4E9AEFD29AEFB49D/Homework/ICRA_AI_Challenge/Jetson4_2_1/SDK/JetPack_4.3_Linux_P3310' -L='/home/greepex/.nvsdkm/logs/JetPack_4.3_Linux' -p='21906' -t='P3310' -e='/media/greepex/4E9AEFD29AEFB49D/Homework/ICRA_AI_Challenge/Jetson4_3/Tegra_Linux_Sample-Root-Filesystem_R32.3.1_aarch64.tbz2' > terminated with error
so, what should i do? Jetson 4.3, Thx
