I am flashing my TX2 with jetpack, and the install is stuck on the “determining IP address of target” line. Both the target and the host are connected to an ethernet switch, however the host does not have an ethernet port so it is connected via a usb to ethernet adapter.
Does anyone know what might be causing this or how to resolve it?
After device flashed, please check if there is IP on your target device.
You can connect a HDMI monitor to your jetson and use ifconfig to check the ip.
If IP is valid, you can open jetpack again and choose only the software package this time. (don’t need to flash the board again). There would be a prompt for IP address this time.
