Is it possible to remove the TX2 module from the SDK and mount it on the Orbitty carrier?
Hi hhemken, yes it is possible, you may need Torx Security Bit Set to remove the module - ex. [1] [2]
Download ConnectTech’s L4T BSP patches from here - http://connecttech.com/product/orbitty-carrier-for-nvidia-jetson-tx2-tx1/
Also see this note from ConnectTech on Orbitty’s TX1/TX2 compatability. You can also contact their Support about it.
Thanks, dusty_nv, that’s the answer I’d hoped for!
