Dear,
I’m using gst-launch-1.0 to play an IP Camera failed, but the IP Camera stream can be played by kmplayer&vlc on Ubuntu x86 pc.
Here is the gst log, I checked it, but can’t found the reason, can anyone help to check about it? Thanks.
GST_DEBUG=4 gst-launch-1.0 rtspsrc location=rtsp:/192.168.2.119/554 ! rtph264depay ! omxh264dec ! nvvidconv ! video/x-raw, width=1920, height=1280, format=BGRx ! videoconvert ! ximagesink
0:00:00.000290048 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_INIT gst.c:511:init_pre:[00m Initializing GStreamer Core Library version 1.8.3
0:00:00.000557216 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_INIT gst.c:512:init_pre:[00m Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.000613312 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_INIT gst.c:523:init_pre:[00m Linux tegra-ubuntu 4.4.38-tegra #21 SMP PREEMPT Tue Nov 6 21:35:03 CST 2018 aarch64
0:00:00.001792320 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_INIT gstmessage.c:119:_priv_gst_message_initialize:[00m init messages
0:00:00.004455584 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_INIT gstcontext.c:83:_priv_gst_context_initialize:[00m init contexts
0:00:00.006256480 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:316:_priv_gst_plugin_initialize:[00m registering 0 static plugins
0:00:00.006909280 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:224:gst_plugin_register_static:[00m registered static plugin "staticelements"
0:00:00.006972640 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static:[00m added static plugin "staticelements", result: 1
0:00:00.007068096 [331m 2958[00m 0x426800 [36mINFO [00m [00m GST_REGISTRY gstregistry.c:1723:ensure_current_registry:[00m reading registry cache: /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.048144768 [331m 2958[00m 0x426800 [36mINFO [00m [00m GST_REGISTRY gstregistrybinary.c:619:priv_gst_registry_binary_read_cache:[00m loaded /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin in 0.041002 seconds
0:00:00.048270528 [331m 2958[00m 0x426800 [36mINFO [00m [00m GST_REGISTRY gstregistry.c:1579:scan_and_update_registry:[00m Validating plugins from registry cache: /home/nvidia/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.049591168 [331m 2958[00m 0x426800 [36mINFO [00m [00m GST_REGISTRY gstregistry.c:1681:scan_and_update_registry:[00m Registry cache has not changed
0:00:00.049622176 [331m 2958[00m 0x426800 [36mINFO [00m [00m GST_REGISTRY gstregistry.c:1758:ensure_current_registry:[00m registry reading and updating done, result = 1
0:00:00.049637344 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_INIT gst.c:724:init_post:[00m GLib runtime version: 2.48.2
0:00:00.049651328 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_INIT gst.c:726:init_post:[00m GLib headers version: 2.48.1
0:00:00.049661888 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_INIT gst.c:727:init_post:[00m initialized GStreamer successfully
0:00:00.049737824 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_PIPELINE gstparse.c:323:gst_parse_launch_full:[00m parsing pipeline description 'rtspsrc location=rtsp://192.168.2.119/554 latency=0 ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw, width=1920, height=1280, format=BGRx ! videoconvert ! ximagesink '
0:00:00.053611840 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstrtsp.so" loaded
0:00:00.053663008 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "rtspsrc"
0:00:00.057578336 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstrtp.so" loaded
0:00:00.057626528 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "rtph264depay"
0:00:00.057805920 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstRTPBaseDepayload@0x5a0150>[00m adding pad 'sink'
0:00:00.057845120 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstRTPBaseDepayload@0x5a0150>[00m adding pad 'src'
0:00:00.058701536 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so" loaded
0:00:00.058728768 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "h264parse"
0:00:00.058845696 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseParse@0x48f560>[00m adding pad 'sink'
0:00:00.058878464 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseParse@0x48f560>[00m adding pad 'src'
0:00:00.058899200 [331m 2958[00m 0x426800 [36mINFO [00m [00m baseparse gstbaseparse.c:3942:gst_base_parse_set_pts_interpolation:<GstH264Parse@0x48f560>[00m PTS interpolation: no
0:00:00.062528896 [331m 2958[00m 0x426800 [33;01mWARN [00m [00m omx gstomx.c:2826:plugin_init:[00m Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/nvidia/.config:/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
0:00:00.062565344 [331m 2958[00m 0x426800 [36mINFO [00m [00m omx gstomx.c:2831:plugin_init:[00m Using default configuration
0:00:00.063005568 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstomx.so" loaded
0:00:00.063030944 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "omxh264dec"
0:00:00.063270432 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstVideoDecoder@0x5c8da0>[00m adding pad 'sink'
0:00:00.063308576 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstVideoDecoder@0x5c8da0>[00m adding pad 'src'
0:00:00.067942752 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so" loaded
0:00:00.067982432 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "nvvidconv"
0:00:00.068223616 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x5e4780>[00m adding pad 'sink'
0:00:00.068260096 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x5e4780>[00m adding pad 'src'
0:00:00.068615072 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideoconvert.so" loaded
0:00:00.068638144 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "videoconvert"
0:00:00.068945376 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x5eb8c0>[00m adding pad 'sink'
0:00:00.068978048 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x5eb8c0>[00m adding pad 'src'
0:00:00.070229376 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstximagesink.so" loaded
0:00:00.070259552 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "ximagesink"
0:00:00.070526720 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSink@0x5f2c20>[00m adding pad 'sink'
0:00:00.070574368 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "pipeline"
0:00:00.070723328 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_PIPELINE grammar.y:596:gst_parse_perform_link:[00m linking some pad of GstRTSPSrc named rtspsrc0 to some pad of GstRtpH264Depay named rtph264depay0 (0/0) with caps "(NULL)"
0:00:00.070751712 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full:[00m trying to link element rtspsrc0:(any) to element rtph264depay0:(any)
0:00:00.070799584 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad:[00m no such pad 'stream_%u' in element "rtspsrc0"
0:00:00.070823232 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1124:gst_element_get_compatible_pad:<rtspsrc0>[00m Could not find a compatible pad to link to rtph264depay0:sink
0:00:00.070837856 [331m 2958[00m 0x426800 [36mINFO [00m [00;04m default gstutils.c:1962:gst_element_link_pads_filtered:[00m Could not link pads: rtspsrc0:(null) - rtph264depay0:(null)
0:00:00.070864992 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_PIPELINE grammar.y:596:gst_parse_perform_link:[00m linking some pad of GstRtpH264Depay named rtph264depay0 to some pad of GstH264Parse named h264parse0 (0/0) with caps "(NULL)"
0:00:00.070885408 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full:[00m trying to link element rtph264depay0:(any) to element h264parse0:(any)
0:00:00.070899936 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link rtph264depay0:src and h264parse0:sink
0:00:00.070923008 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:4098:gst_pad_peer_query:<h264parse0:src>[00m pad has no peer
0:00:00.070940736 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting:[00m rtph264depay0 and h264parse0 in same bin, no need for ghost pads
0:00:00.070963072 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link rtph264depay0:src and h264parse0:sink
0:00:00.070984448 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:4098:gst_pad_peer_query:<h264parse0:src>[00m pad has no peer
0:00:00.070996480 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked rtph264depay0:src and h264parse0:sink, successful
0:00:00.071011104 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.071020384 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<rtph264depay0:src>[00m Received event on flushing pad. Discarding
0:00:00.071037856 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_PIPELINE grammar.y:596:gst_parse_perform_link:[00m linking some pad of GstH264Parse named h264parse0 to some pad of GstOMXH264Dec-omxh264dec named omxh264dec-omxh264dec0 (0/0) with caps "(NULL)"
0:00:00.071053728 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full:[00m trying to link element h264parse0:(any) to element omxh264dec-omxh264dec0:(any)
0:00:00.071066144 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link h264parse0:src and omxh264dec-omxh264dec0:sink
0:00:00.071087360 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:4098:gst_pad_peer_query:<omxh264dec-omxh264dec0:src>[00m pad has no peer
0:00:00.071139392 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting:[00m h264parse0 and omxh264dec-omxh264dec0 in same bin, no need for ghost pads
0:00:00.071160704 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link h264parse0:src and omxh264dec-omxh264dec0:sink
0:00:00.071182496 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:4098:gst_pad_peer_query:<omxh264dec-omxh264dec0:src>[00m pad has no peer
0:00:00.071216544 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked h264parse0:src and omxh264dec-omxh264dec0:sink, successful
0:00:00.071230912 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.071238720 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<h264parse0:src>[00m Received event on flushing pad. Discarding
0:00:00.071253536 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_PIPELINE grammar.y:596:gst_parse_perform_link:[00m linking some pad of GstOMXH264Dec-omxh264dec named omxh264dec-omxh264dec0 to some pad of Gstnvvconv named nvvconv0 (0/0) with caps "(NULL)"
0:00:00.071272896 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full:[00m trying to link element omxh264dec-omxh264dec0:(any) to element nvvconv0:(any)
0:00:00.071286080 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link omxh264dec-omxh264dec0:src and nvvconv0:sink
0:00:00.071305856 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvvconv0:src>[00m pad has no peer
0:00:00.071411360 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting:[00m omxh264dec-omxh264dec0 and nvvconv0 in same bin, no need for ghost pads
0:00:00.071432480 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link omxh264dec-omxh264dec0:src and nvvconv0:sink
0:00:00.071455680 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:4098:gst_pad_peer_query:<nvvconv0:src>[00m pad has no peer
0:00:00.071540192 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked omxh264dec-omxh264dec0:src and nvvconv0:sink, successful
0:00:00.071557056 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.071565632 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<omxh264dec-omxh264dec0:src>[00m Received event on flushing pad. Discarding
0:00:00.071580320 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_PIPELINE grammar.y:596:gst_parse_perform_link:[00m linking some pad of Gstnvvconv named nvvconv0 to some pad of GstVideoConvert named videoconvert0 (0/0) with caps "video/x-raw, width=(int)1920, height=(int)1280, format=(string)BGRx"
0:00:00.072349280 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.072379456 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "capsfilter"
0:00:00.072494304 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x602340>[00m adding pad 'sink'
0:00:00.072545760 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseTransform@0x602340>[00m adding pad 'src'
0:00:00.072570880 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:1915:gst_bin_get_state_func:<pipeline0>[00m getting state
0:00:00.072613824 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0>[00m completed state change to NULL
0:00:00.072636576 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.072652896 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full:[00m trying to link element nvvconv0:(any) to element capsfilter0:sink
0:00:00.072668352 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad capsfilter0:sink
0:00:00.072678720 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting:[00m nvvconv0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.072696000 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link nvvconv0:src and capsfilter0:sink
0:00:00.072819296 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:4098:gst_pad_peer_query:<capsfilter0:src>[00m pad has no peer
0:00:00.072843488 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked nvvconv0:src and capsfilter0:sink, successful
0:00:00.072859904 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.072868256 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<nvvconv0:src>[00m Received event on flushing pad. Discarding
0:00:00.072883200 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full:[00m trying to link element capsfilter0:src to element videoconvert0:(any)
0:00:00.072897184 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad capsfilter0:src
0:00:00.072908480 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link capsfilter0:src and videoconvert0:sink
0:00:00.073021536 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:4098:gst_pad_peer_query:<videoconvert0:src>[00m pad has no peer
0:00:00.073903520 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting:[00m capsfilter0 and videoconvert0 in same bin, no need for ghost pads
0:00:00.073925664 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link capsfilter0:src and videoconvert0:sink
0:00:00.074038720 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:4098:gst_pad_peer_query:<videoconvert0:src>[00m pad has no peer
0:00:00.074930464 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked capsfilter0:src and videoconvert0:sink, successful
0:00:00.074952224 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.074960832 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<capsfilter0:src>[00m Received event on flushing pad. Discarding
0:00:00.074976480 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_PIPELINE grammar.y:596:gst_parse_perform_link:[00m linking some pad of GstVideoConvert named videoconvert0 to some pad of GstXImageSink named ximagesink0 (0/0) with caps "(NULL)"
0:00:00.075001856 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full:[00m trying to link element videoconvert0:(any) to element ximagesink0:(any)
0:00:00.075015584 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:932:gst_pad_check_link:[00m trying to link videoconvert0:src and ximagesink0:sink
0:00:00.075229120 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting:[00m videoconvert0 and ximagesink0 in same bin, no need for ghost pads
0:00:00.075251648 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link videoconvert0:src and ximagesink0:sink
0:00:00.075455008 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked videoconvert0:src and ximagesink0:sink, successful
0:00:00.075470592 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.075479008 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<videoconvert0:src>[00m Received event on flushing pad. Discarding
Setting pipeline to PAUSED ...
0:00:00.075552512 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<ximagesink0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.076503776 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<ximagesink0>[00m completed state change to READY
0:00:00.076528192 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<ximagesink0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.076560416 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'ximagesink0' changed state to 2(READY) successfully
0:00:00.076583040 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<videoconvert0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.076600640 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<videoconvert0>[00m completed state change to READY
0:00:00.076609760 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<videoconvert0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.076624096 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'videoconvert0' changed state to 2(READY) successfully
0:00:00.076643872 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.076659744 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0>[00m completed state change to READY
0:00:00.076668288 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.076681920 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'capsfilter0' changed state to 2(READY) successfully
0:00:00.076699296 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvconv0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.076715840 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvconv0>[00m completed state change to READY
0:00:00.076724736 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvconv0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.076737248 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'nvvconv0' changed state to 2(READY) successfully
0:00:00.076754880 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<omxh264dec-omxh264dec0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.080085408 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<omxh264dec-omxh264dec0>[00m completed state change to READY
0:00:00.080118752 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<omxh264dec-omxh264dec0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.080146976 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'omxh264dec-omxh264dec0' changed state to 2(READY) successfully
0:00:00.080173376 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<h264parse0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.080193216 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<h264parse0>[00m completed state change to READY
0:00:00.080206848 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<h264parse0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.080222272 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'h264parse0' changed state to 2(READY) successfully
0:00:00.080235712 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<rtph264depay0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.080249664 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<rtph264depay0>[00m completed state change to READY
0:00:00.080257792 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtph264depay0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.080270976 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'rtph264depay0' changed state to 2(READY) successfully
0:00:00.080285952 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<rtspsrc0>[00m current NULL pending VOID_PENDING, desired next READY
0:00:00.080328192 [331m 2958[00m 0x426800 [36mINFO [00m [00m task gsttask.c:451:gst_task_set_lock:[00m setting stream lock 0x5931a8 on task 0x622050
0:00:00.080358432 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<rtspsrc0>[00m completed state change to READY
0:00:00.080371776 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtspsrc0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.080387744 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'rtspsrc0' changed state to 2(READY) successfully
0:00:00.080405280 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2347:gst_element_continue_state:<pipeline0>[00m committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.080418528 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<pipeline0>[00m notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.080470624 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2354:gst_element_continue_state:<pipeline0>[00m continue state change READY to PAUSED, final PAUSED
0:00:00.080508000 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<ximagesink0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.080538560 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2770:gst_bin_change_state_func:<pipeline0>[00m child 'ximagesink0' is changing state asynchronously to PAUSED
0:00:00.080557216 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<videoconvert0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.080579680 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<videoconvert0>[00m completed state change to PAUSED
0:00:00.080591776 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<videoconvert0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.080606112 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'videoconvert0' changed state to 3(PAUSED) successfully
0:00:00.080623744 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.080641280 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0>[00m completed state change to PAUSED
0:00:00.080650112 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.080663648 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:00.080680128 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvconv0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.094536384 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvconv0>[00m completed state change to PAUSED
0:00:00.094585440 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvconv0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.094626848 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'nvvconv0' changed state to 3(PAUSED) successfully
0:00:00.094667616 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<omxh264dec-omxh264dec0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.094715392 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<omxh264dec-omxh264dec0>[00m completed state change to PAUSED
0:00:00.094734400 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<omxh264dec-omxh264dec0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.094781280 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'omxh264dec-omxh264dec0' changed state to 3(PAUSED) successfully
0:00:00.094806848 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<h264parse0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.095221824 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<h264parse0>[00m completed state change to PAUSED
0:00:00.095250560 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<h264parse0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.095289536 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'h264parse0' changed state to 3(PAUSED) successfully
0:00:00.095309568 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<rtph264depay0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.095336704 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<rtph264depay0>[00m completed state change to PAUSED
0:00:00.095349504 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtph264depay0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.095367264 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'rtph264depay0' changed state to 3(PAUSED) successfully
0:00:00.095394720 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<rtspsrc0>[00m current READY pending VOID_PENDING, desired next PAUSED
0:00:00.095525312 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<rtspsrc0>[00m completed state change to PAUSED
0:00:00.095550432 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtspsrc0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.095573952 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2807:gst_bin_change_state_func:<pipeline0>[00m child 'rtspsrc0' changed state to 3(PAUSED) successfully without preroll
0:00:00.095596512 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<pipeline0>[00m completed state change to PAUSED
0:00:00.095614112 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<pipeline0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://192.168.2.119/554
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
0:00:00.515293664 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstudp.so" loaded
0:00:00.515451104 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "udpsrc"
0:00:00.516296544 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSrc@0x7f900188d0>[00m adding pad 'src'
0:00:00.516827072 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00m udpsrc gstudpsrc.c:1367:gst_udpsrc_open:<udpsrc0>[00m setting udp buffer of 524288 bytes
0:00:00.516924864 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00m udpsrc gstudpsrc.c:1387:gst_udpsrc_open:<udpsrc0>[00m have udp buffer of 458752 bytes
0:00:00.517081920 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<udpsrc0>[00m completed state change to READY
0:00:00.517158176 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<udpsrc0>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.517597344 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "udpsrc"
0:00:00.517802656 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSrc@0x7f90018e20>[00m adding pad 'src'
0:00:00.518257440 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00m udpsrc gstudpsrc.c:1387:gst_udpsrc_open:<udpsrc1>[00m have udp buffer of 229376 bytes
0:00:00.518547712 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<udpsrc1>[00m completed state change to READY
0:00:00.518629120 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<udpsrc1>[00m notifying about state-changed NULL to READY (VOID_PENDING pending)
Progress: (request) SETUP stream 0
0:00:00.700256672 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;36m GST_PLUGIN_LOADING gstplugin.c:842:_priv_gst_plugin_load_file_for_registry:[00m plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstrtpmanager.so" loaded
0:00:00.700438848 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:362:gst_element_factory_create:[00m creating element "rtpbin" named "manager"
0:00:00.702810464 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2347:gst_element_continue_state:<manager>[00m committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.702936800 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<manager>[00m notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.703106048 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2354:gst_element_continue_state:<manager>[00m continue state change READY to PAUSED, final PAUSED
0:00:00.703231840 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<manager>[00m completed state change to PAUSED
0:00:00.703339424 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<manager>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.703733696 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad:[00m no such pad 'recv_rtp_sink_0' in element "manager"
0:00:00.703855296 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "rtpsession"
0:00:00.706183808 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "rtpssrcdemux"
0:00:00.706976416 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstRtpSsrcDemux@0x7f90032030>[00m adding pad 'sink'
0:00:00.707091040 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstRtpSsrcDemux@0x7f90032030>[00m adding pad 'rtcp_sink'
0:00:00.707437632 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2347:gst_element_continue_state:<rtpssrcdemux0>[00m committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.707503520 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtpssrcdemux0>[00m notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.707606688 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2354:gst_element_continue_state:<rtpssrcdemux0>[00m continue state change READY to PAUSED, final PAUSED
0:00:00.707679936 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<rtpssrcdemux0>[00m completed state change to PAUSED
0:00:00.707716384 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtpssrcdemux0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.707808704 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2347:gst_element_continue_state:<rtpsession0>[00m committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.707865888 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtpsession0>[00m notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.707958176 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2354:gst_element_continue_state:<rtpsession0>[00m continue state change READY to PAUSED, final PAUSED
0:00:00.708011872 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<rtpsession0>[00m completed state change to PAUSED
0:00:00.708045760 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<rtpsession0>[00m notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.708131296 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad:[00m no such pad 'recv_rtp_sink' in element "rtpsession0"
0:00:00.708292544 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<rtpsession0>[00m adding pad 'recv_rtp_sink'
0:00:00.708434272 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<rtpsession0>[00m adding pad 'recv_rtp_src'
0:00:00.708762464 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link recv_rtp_sink_0:proxypad0 and rtpsession0:recv_rtp_sink
0:00:00.708834080 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked recv_rtp_sink_0:proxypad0 and rtpsession0:recv_rtp_sink, successful
0:00:00.708879168 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.708952352 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<manager>[00m adding pad 'recv_rtp_sink_0'
0:00:00.709020608 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad rtpsession0:recv_rtp_src
0:00:00.709089376 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad rtpssrcdemux0:sink
0:00:00.709204224 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link rtpsession0:recv_rtp_src and rtpssrcdemux0:sink
0:00:00.709296416 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked rtpsession0:recv_rtp_src and rtpssrcdemux0:sink, successful
0:00:00.709362688 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.709508992 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad:[00m no such pad 'recv_rtcp_sink_0' in element "manager"
0:00:00.709605600 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad:[00m no such pad 'recv_rtcp_sink' in element "rtpsession0"
0:00:00.709795392 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<rtpsession0>[00m adding pad 'recv_rtcp_sink'
0:00:00.709989664 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<rtpsession0>[00m adding pad 'sync_src'
0:00:00.710118432 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad rtpsession0:sync_src
0:00:00.710199744 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad rtpssrcdemux0:rtcp_sink
0:00:00.710339744 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link rtpsession0:sync_src and rtpssrcdemux0:rtcp_sink
0:00:00.710420960 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked rtpsession0:sync_src and rtpssrcdemux0:rtcp_sink, successful
0:00:00.710478048 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.710702912 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link recv_rtcp_sink_0:proxypad1 and rtpsession0:recv_rtcp_sink
0:00:00.710798560 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked recv_rtcp_sink_0:proxypad1 and rtpsession0:recv_rtcp_sink, successful
0:00:00.710861344 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.710936576 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<manager>[00m adding pad 'recv_rtcp_sink_0'
0:00:00.711059616 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00m rtspsrc gstrtspsrc.c:3110:gst_rtspsrc_stream_configure_manager:<rtspsrc0>[00m configure bandwidth in session 0x602f30
0:00:00.711133184 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00m rtspsrc gstrtspsrc.c:3121:gst_rtspsrc_stream_configure_manager:<rtspsrc0>[00m setting RR: 0
0:00:00.711391648 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad udpsrc0:src
0:00:00.711533056 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link udpsrc0:src and manager:recv_rtp_sink_0
0:00:00.711620864 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked udpsrc0:src and manager:recv_rtp_sink_0, successful
0:00:00.711682976 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.711727872 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<udpsrc0:src>[00m Received event on flushing pad. Discarding
0:00:00.711890176 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad udpsrc1:src
0:00:00.711997856 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link udpsrc1:src and manager:recv_rtcp_sink_0
0:00:00.712080384 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked udpsrc1:src and manager:recv_rtcp_sink_0, successful
0:00:00.712139584 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.712181632 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<udpsrc1:src>[00m Received event on flushing pad. Discarding
0:00:00.712750592 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "udpsink"
0:00:00.713735040 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSink@0x7f9003a410>[00m adding pad 'sink'
0:00:00.719148832 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "fakesrc"
0:00:00.720001504 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSrc@0x7f9003e1a0>[00m adding pad 'src'
0:00:00.720308672 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstutils.c:1573:gst_element_link_pads_full:[00m trying to link element fakesrc0:src to element udpsink0:sink
0:00:00.720415840 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad fakesrc0:src
0:00:00.720475872 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad udpsink0:sink
0:00:00.720526688 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstutils.c:1446:prepare_link_maybe_ghosting:[00m fakesrc0 and udpsink0 in same bin, no need for ghost pads
0:00:00.720620800 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link fakesrc0:src and udpsink0:sink
0:00:00.720709472 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked fakesrc0:src and udpsink0:sink, successful
0:00:00.720772064 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.720819072 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstpad.c:5634:gst_pad_send_event_unchecked:<fakesrc0:src>[00m Received event on flushing pad. Discarding
0:00:00.721346016 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_FACTORY gstelementfactory.c:364:gst_element_factory_create:[00m creating element "udpsink"
0:00:00.721548352 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<GstBaseSink@0x7f9003d610>[00m adding pad 'sink'
0:00:00.723000000 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2347:gst_element_continue_state:<udpsink1>[00m committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:00.723087904 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<udpsink1>[00m notifying about state-changed NULL to READY (PLAYING pending)
0:00:00.723153280 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2354:gst_element_continue_state:<udpsink1>[00m continue state change READY to PAUSED, final PLAYING
0:00:00.723221728 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2347:gst_element_continue_state:<udpsink1>[00m committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:00.723283360 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<udpsink1>[00m notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:00.723332544 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2354:gst_element_continue_state:<udpsink1>[00m continue state change PAUSED to PLAYING, final PLAYING
0:00:00.723372768 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<udpsink1>[00m completed state change to PLAYING
0:00:00.723406336 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<udpsink1>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.723512832 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:907:gst_element_get_static_pad:[00m found pad udpsink1:sink
0:00:00.723604704 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad:[00m no such pad 'send_rtcp_src_0' in element "manager"
0:00:00.723676480 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:904:gst_element_get_static_pad:[00m no such pad 'send_rtcp_src' in element "rtpsession0"
0:00:00.723858368 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<rtpsession0>[00m adding pad 'send_rtcp_src'
0:00:00.724098752 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link rtpsession0:send_rtcp_src and send_rtcp_src_0:proxypad2
0:00:00.724172480 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked rtpsession0:send_rtcp_src and send_rtcp_src_0:proxypad2, successful
0:00:00.724219040 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
0:00:00.724295392 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;37;41m GST_ELEMENT_PADS gstelement.c:659:gst_element_add_pad:<manager>[00m adding pad 'send_rtcp_src_0'
0:00:00.724385184 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2315:gst_pad_link_prepare:[00m trying to link manager:send_rtcp_src_0 and udpsink1:sink
0:00:00.724446816 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;31;41m GST_PADS gstpad.c:2521:gst_pad_link_full:[00m linked manager:send_rtcp_src_0 and udpsink1:sink, successful
0:00:00.724488640 [331m 2958[00m 0x5c88a0 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1382:gst_event_new_reconfigure:[00m creating reconfigure event
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
0:00:00.725194048 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;34m GST_EVENT gstevent.c:1253:gst_event_new_latency:[00m creating latency event 0:00:00.000000000
0:00:00.725372032 [331m 2958[00m 0x426800 [36mINFO [00m [00;01m bin gstbin.c:2593:gst_bin_do_latency_func:<pipeline0>[00m configured latency of 0:00:00.000000000
0:00:00.725512672 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<ximagesink0>[00m current READY pending PAUSED, desired next PLAYING
0:00:00.725578944 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2770:gst_bin_change_state_func:<pipeline0>[00m child 'ximagesink0' is changing state asynchronously to PLAYING
0:00:00.725633408 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<videoconvert0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.725699616 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<videoconvert0>[00m completed state change to PLAYING
0:00:00.725735520 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<videoconvert0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.725797792 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'videoconvert0' changed state to 4(PLAYING) successfully
0:00:00.725867840 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<capsfilter0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.725928608 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<capsfilter0>[00m completed state change to PLAYING
0:00:00.725963136 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<capsfilter0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.726020960 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'capsfilter0' changed state to 4(PLAYING) successfully
0:00:00.726077312 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<nvvconv0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.726143904 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<nvvconv0>[00m completed state change to PLAYING
0:00:00.726180288 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<nvvconv0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.726235584 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'nvvconv0' changed state to 4(PLAYING) successfully
0:00:00.726373600 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<omxh264dec-omxh264dec0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.726442528 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<omxh264dec-omxh264dec0>[00m completed state change to PLAYING
0:00:00.726491712 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<omxh264dec-omxh264dec0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.726552800 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'omxh264dec-omxh264dec0' changed state to 4(PLAYING) successfully
0:00:00.726623392 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<h264parse0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.726686112 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<h264parse0>[00m completed state change to PLAYING
0:00:00.726720896 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2277:_priv_gst_element_state_changed:<h264parse0>[00m notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:00.726773248 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2764:gst_bin_change_state_func:<pipeline0>[00m child 'h264parse0' changed state to 4(PLAYING) successfully
0:00:00.726838656 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstbin.c:2316:gst_bin_element_set_state:<rtph264depay0>[00m current PAUSED pending VOID_PENDING, desired next PLAYING
0:00:00.726904736 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES gstelement.c:2372:gst_element_continue_state:<rtph264depay0>[00m completed state change to PLAYING
0:00:00.726939520 [331m 2958[00m 0x426800 [36mINFO [00m [00;01;31m GST_STATES
