HI,
IDT PCIe switch connected to jetson tx2.
The IDT switch is connected to the board that drives the NTB developed by us.
The transfer of data from the jetson through the NTB port is usually done.
However, there is a problem with the interrupt.
The system hangs when a write operation is performed on the register associated with the IDT switch interrupt.
Unlike a simple interrupt congestion problem, when an interrupt is generated, isr is executed, but the time at which isr is executed is significantly slower(4~5sec) than the interrupt. Also, various kernel error logs are printed before and after isr is executed.
Below is the dmesg log.
[ 134.938548] INFO: rcu_sched detected stalls on CPUs/tasks:
[ 134.942874] 0-…: (1 ticks this GP) idle=caf/2/0 softirq=12410/12410 fqs=0
[ 134.950147] (detected by 1, t=5252 jiffies, g=767, c=766, q=14)
[ 134.956242] Task dump for CPU 0:
[ 134.956266] swapper/0 R running task 0 0 0 0x00000002
[ 134.956322] Call trace:
[ 134.956456] [] __switch_to+0x9c/0xc0
[ 134.956508] [] cpuidle_enter_state+0xa0/0x380
[ 134.956598] [] cpuidle_enter+0x34/0x48
[ 134.956629] [] call_cpuidle+0x44/0x70
[ 134.956657] [] cpu_startup_entry+0x1b0/0x200
[ 134.956691] [] rest_init+0x84/0x90
[ 134.956722] [] start_kernel+0x370/0x384
[ 134.956757] [] __primary_switched+0x80/0x94
[ 134.956875] rcu_sched kthread starved for 5252 jiffies! g767 c766 f0x0 RCU_GP_WAIT_FQS(3) ->state=0x1
[ 134.966130] rcu_sched S 0 8 2 0x00000000
[ 134.966169] Call trace:
[ 134.966269] [] __switch_to+0x9c/0xc0
[ 134.966300] [] __schedule+0x270/0x780
[ 134.966325] [] schedule+0x40/0xa8
[ 134.966383] [] schedule_timeout+0x88/0x420
[ 134.966415] [] rcu_gp_kthread+0x4a4/0x7d8
[ 134.966442] [] kthread+0xec/0xf0
[ 134.966467] [] ret_from_fork+0x10/0x40
[ 134.966732] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 134.972489] 0-…: (2 GPs behind) idle=caf/2/0 softirq=12410/12410 fqs=2539
[ 134.979663] (detected by 1, t=5257 jiffies, g=3826, c=3825, q=97)
[ 134.985919] Task dump for CPU 0:
[ 134.985936] swapper/0 R running task 0 0 0 0x00000002
[ 134.985984] Call trace:
[ 134.986053] [] __switch_to+0x9c/0xc0
[ 134.986174] [] cpuidle_enter_state+0xa0/0x380
[ 134.986199] [] cpuidle_enter+0x34/0x48
[ 134.986223] [] call_cpuidle+0x44/0x70
[ 134.986247] [] cpu_startup_entry+0x1b0/0x200
[ 134.986273] [] rest_init+0x84/0x90
[ 134.986295] [] start_kernel+0x370/0x384
[ 134.986324] [] __primary_switched+0x80/0x94
