1.准备一个已知的256字节EDID。
2. set use_fallback = true; 在edid.c中的tegra_edid_get_monspecs()中。
3.将已知的EDID填入default_720p_edid [256]。
I modified the file, but it does not seem to change.
int tegra_edid_get_monspecs(struct tegra_edid *edid, struct fb_monspecs *specs)
int i;
int j;
int ret;
int extension_blocks;
struct tegra_edid_pvt *new_data, *old_data;
u8 checksum = 0;
u8 *data;
//bool use_fallback = false;
bool use_fallback = true;
new_data = vzalloc(SZ_32K + sizeof(struct tegra_edid_pvt));
if (!new_data)
return -ENOMEM;
kref_init(&new_data->refcnt);
if (edid->errors & EDID_ERRORS_READ_FAILED)
edid->errors = 0;
data = new_data->dc_edid.buf;
static const char default_720p_edid[256] = {
0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00,
0x49, 0xF7, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x01, 0x1A, 0x01, 0x03, 0x80, 0x00, 0x00, 0x00,
0x0A, 0xD7, 0xA5, 0xA2, 0x59, 0x4A, 0x96, 0x24,
0x14, 0x50, 0x54, 0xAF, 0xCE, 0x00, 0x81, 0xC0,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x12, 0x1B,
0x00, 0x7B, 0x50, 0x20, 0x15, 0x30, 0x30, 0x20,
0x36, 0x00, 0x05, 0xA3, 0x10, 0x00, 0x00, 0x18,
0x0E, 0x1F, 0x00, 0x80, 0x51, 0x00, 0x1E, 0x30,
0x40, 0x80, 0x37, 0x00, 0x20, 0x56, 0x00, 0x00,
0x00, 0x1C, 0x00, 0x00, 0x00, 0xFD, 0x00, 0x32,
0x4C, 0x1E, 0x50, 0x10, 0x00, 0x0A, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0xFC,
0x00, 0x41, 0x41, 0x41, 0x0A, 0x20, 0x20, 0x20,
0x20, 0x20, 0x20, 0x20, 0x20, 0x0A, 0x01, 0xFF,
0x02, 0x03, 0x23, 0x74, 0x4F, 0x10, 0x9F, 0x14,
0x05, 0x04, 0x13, 0x12, 0x16, 0x11, 0x15, 0x03,
0x07, 0x02, 0x06, 0x01, 0x23, 0x09, 0x0F, 0x03,
0x83, 0x01, 0x00, 0x00, 0x66, 0x03, 0x0C, 0x00,
0x10, 0x00, 0x80, 0x01, 0x1D, 0x00, 0xBC, 0x52,
0xD0, 0x1E, 0x20, 0xB8, 0x28, 0x55, 0x40, 0xC4,
0x8E, 0x21, 0x00, 0x00, 0x1E, 0x01, 0x1D, 0x80,
0xD0, 0x72, 0x1C, 0x16, 0x20, 0x10, 0x2C, 0x25,
0x80, 0xC4, 0x8E, 0x21, 0x00, 0x00, 0x9E, 0x8C,
0x0A, 0xD0, 0x8A, 0x20, 0xE0, 0x2D, 0x10, 0x10,
0x3E, 0x96, 0x00, 0x13, 0x8E, 0x21, 0x00, 0x00,
0x18, 0x8C, 0x0A, 0xD0, 0x90, 0x20, 0x40, 0x31,
0x20, 0x0C, 0x40, 0x55, 0x00, 0x13, 0x8E, 0x21,
0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x9D
