TX2(i): Disable spread spectrum clock
I found here the following link:
https://devtalk.nvidia.com/default/topic/1066076/jetson-tx2/how-to-disable-ssc-/?offset=2#5398648
It explains how to disable SCC in TX2:
“Please convert bpmp dtb to dts and put this to it.”
Can you please explain where can I find “dpmp dtb” ?
Thank you in advance,
Zvika
Please take a look:
https://devtalk.nvidia.com/default/topic/1066505/jetson-tx2/disable-spread-spectrum-in-tx2-r28-2-1/post/5402814/#5402814
Thank you very much for your reply.
Is there a documentation what is the purpose of each dtb ?
Best regards,
Zvika
How about reading the l4t documentation first?
https://developer.nvidia.com/embedded/dlc/l4t-documentation-28.3
I tried:
sudo ./flash.sh -d bootloader/t186ref/tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1.dtb jetson-tx2i mmcblk0p1
But this caused the TX2i to hang while booting.
I got the NVIDIA logo forever.
In the documentation, I did not find what is each dtb.
Thank you,
Zvika
Please do the full flash instead of each dtb in this case.
I did not understand your reply.
What should I do after:
sudo ./flash.sh jetson-tx2i mmcblk0p1 ?
The original jetson-tx2i.conf contains the line:
BPFDTB_FILE=tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1.dtb
Should I do any modification in a dtb \ conf ?
Thank you very much for your help,
Zvika
Follwing are the steps I did:
  1. dtc -I dtb -O dts tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1.dtb > tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1.dts
  2. cp tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1.dts tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1-ssc-disable.dts
  3. add the following section in tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1-ssc-disable.dts
    clocks {
    clock@plle {
    clk-id = <0x200>;
    /* disable ssc on PLLE */
    pll_freq_table = <38400000 100000000 2 125 24 (-1) (-1) (-1) (-1)>;
  4. dtc -I dts -O dtb tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1-ssc-disable.dts > tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1-ssc-disable.dtb
  5. Modified jetson-tx2i.conf to use the new tegra-186-a02-bpmp-storm-p3489-a00-00-ta795sa-ucm1-ssc-disable.dtb
Thank you,
Zvika
