situation:
I’m connecting a tx2 over a HAMA regulated switching power DC/DC Converter (12V, 2000mA) to a 12V plug in the car. The VDD_IN_LED lights up, but the device does not boot.
questions
Do I need a power converter with a higher current? e.g. rated 90W
Any suggestions proved to work?
Would a simple USB to barrel plug 5 x 2.5 work as well?
Beware that the Jetson is sensitive to voltage fluctuation right at the moment of starting. If your barrel connector is not correct, or if too small of a gauge of wire is used, or if for any reason the initial current spike isn’t well handled, then it won’t boot.
I don’t know if it is actually correct, but the ones I’ve used in the past are the larger 2.5mm actual inner diameter.
I would suggest to start testing by adding a large capacitor right next to the barrel connector…at least several thousand uF. If that works, then it might be the initial current spike wasn’t well handled. If it didn’t work, then try a different connector like the 2.5mm “actual” inner diameter.
