TX2 INSTALL TENSOR2TENSOR
Hi, could you help me ?
When I use :
pip3 install tensor2tensor
I get Error like this :
“ERROR: Could not find a version that satisfies the requirement opencv-python (from tensor2tensor) (from versions: none)
ERROR: No matching distribution found for opencv-python (from tensor2tensor)”
But I have installed opencv-python through
wget https://github.com/opencv/opencv/archive/3.4.3.zip
unzip 3.4.3.zip
and make it , so in python3 I can " import cv2 ". After installing opencv-python, I start to install tensor2tensor , unfortunately , I get the error above, what should I do to fix this problem ?
Thank you very much !
It looks like tensor2tensor doesn’t support Jetson platform:
[url]https://github.com/tensorflow/tensor2tensor/issues/1657[/url]
It’s recommended to check with TensorFlowe team for some suggestion first.
Thank you for your recommendation ! I hope I could get some helps from them.
