Tx2 installation stops in between with an error
Host Machine : Ubuntu 18.04 amd64
target h/w :jetson tx2
while flashing/installation the process stops in between and installation errror is happening i retried for the 7th time but nothing is working
i searched on nvidia forum but couldn’t find a proper explantion and solution
here is exported log for your furthue reference to troubleshoot the cause
thank you in advance
SDKM_logs_JetPack_4.6.2_Linux_for_Jetson_TX2_modules_2022-09-07_16-17-37.zip (130.4 KB)
You should try to read the error log and search it on forum.
Your issue is nothing new.
16:21:24.011 - info: NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP@JETSON_TX2_TARGETS: 1. The root filesystem, provided with this package,
16:21:24.011 - info: NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP@JETSON_TX2_TARGETS:    has to be extracted to this directory:
16:21:24.011 - info: NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP@JETSON_TX2_TARGETS:    /media/ubuntu/OldUbuntu/TX2/TargeHW/JetPack_4.6.2_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/rootfs
16:21:24.011 - info: NV_L4T_FILE_SYSTEM_AND_OS_T186_COMP@JETSON_TX2_TARGETS: -----------------------------------------------------
Please make sure the disk you are using to download sdkmanager is ext4 partition.
