Hello everyone,
I am using a TX2 with orbitty carrier board mounted on a DJI matrice 600 drone.
I have one issue where whenever TX2 is close to the GPS antenna (10cm+), the GPS signal gets jammed.
When I increase the separation distance, it works fine.
Alternatively, if I put a metal shield in between the two, they do not interfere.
Has anyone had a similar issue to me?
If so, what can I do to fix this issue? (besides installing a metal shield).
