I am evaluating the display PWM of TX2. For that i have probed display connector of the nvidia carrier board. During testing something is happened, now the TX2 SOM is not working, there is no log in the UART also. But the carrier board is working perfectly with another SOM.
Please help me to debug that SOM.
Hi, it looks like some component broken during your probe test. You can probe each pin of display connector to see if any shorted to ground unexpected first.
The SOM only not working, the carrier board works fine with another SOM.
Is there any way to recover that SOM?
First, you need to find out if any component in module broken by probing the pins of display connector. Then will can analyse if any way to fix it. Or you can go RMA process directly.
