I am trying to flash Jetpack 3.2 on to TX2. I have ubuntu16.04 host, Tx2 gets recognized and shows up in lsusb.
Flash works until [ 14.0528 ] Writing partition APP with system.img
it errors out as below
[ 14.1009 ] [… ] 025%
[ 1234.6186 ]
Error: Return value 3
Command tegradevflash_v2 --pt flash.xml.bin --create
Failed flashing t186ref.
I can send the complete log file. There are no space constraint in the box.
Filesystem Size Used Avail Use% Mounted on
udev 2.0G 0 2.0G 0% /dev
tmpfs 395M 6.1M 389M 2% /run
/dev/sda1 193G 25G 159G 14% /
tmpfs 2.0G 188K 2.0G 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
tmpfs 395M 48K 395M 1% /run/user/1000
cs@csvm:~$ lsusb
Bus 001 Device 004: ID 0955:7c18 NVidia Corp.
Bus 001 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
flash_os_tx2.log (246 KB)
