Hi JerryChang,
My tx2 working wich JetPack4.2,and 4K30fps YUV422 8bit mipi csi-2 video stream connect to tx2 csi-port AB, so I set ‘csi_pixel_bit_depth = “8”;’.
camera_common_colorfmt & extract_pixel_format() as follows
static const struct camera_common_colorfmt camera_common_color_fmts[] = {
MEDIA_BUS_FMT_SRGGB12_1X12,
V4L2_COLORSPACE_SRGB,
V4L2_PIX_FMT_SRGGB12,
MEDIA_BUS_FMT_SGRBG12_1X12,
V4L2_PIX_FMT_SGRBG12,
MEDIA_BUS_FMT_SRGGB10_1X10,
V4L2_PIX_FMT_SRGGB10,
MEDIA_BUS_FMT_SGRBG10_1X10,
V4L2_PIX_FMT_SGRBG10,
MEDIA_BUS_FMT_SBGGR10_1X10,
V4L2_PIX_FMT_SBGGR10,
MEDIA_BUS_FMT_SRGGB8_1X8,
V4L2_PIX_FMT_SRGGB8,
MEDIA_BUS_FMT_YUYV8_1X16,
V4L2_PIX_FMT_YUYV,
MEDIA_BUS_FMT_YVYU8_1X16,
V4L2_PIX_FMT_YVYU,
MEDIA_BUS_FMT_UYVY8_1X16,
V4L2_PIX_FMT_UYVY,
MEDIA_BUS_FMT_VYUY8_1X16,
V4L2_PIX_FMT_VYUY,
MEDIA_BUS_FMT_YUYV8_2X8,
V4L2_PIX_FMT_YUYV,
MEDIA_BUS_FMT_YVYU8_2X8,
V4L2_PIX_FMT_YVYU,
MEDIA_BUS_FMT_UYVY8_2X8,
V4L2_PIX_FMT_UYVY,
MEDIA_BUS_FMT_VYUY8_2X8,
V4L2_PIX_FMT_VYUY,
* The below two formats are not supported by VI4,
* keep them at the last to ensure they get discarded
MEDIA_BUS_FMT_XRGGB10P_3X10,
V4L2_PIX_FMT_XRGGB10P,
MEDIA_BUS_FMT_XBGGR10P_3X10,
static int extract_pixel_format(
const char *pixel_t, u32 *format)
size_t size = strnlen(pixel_t, OF_MAX_STR_LEN);
if (strncmp(pixel_t, "bayer_bggr10", size) == 0)
*format = V4L2_PIX_FMT_SBGGR10;
else if (strncmp(pixel_t, "bayer_rggb10", size) == 0)
*format = V4L2_PIX_FMT_SRGGB10;
else if (strncmp(pixel_t, "bayer_grbg10", size) == 0)
*format = V4L2_PIX_FMT_SGRBG10;
else if (strncmp(pixel_t, "bayer_bggr12", size) == 0)
*format = V4L2_PIX_FMT_SBGGR12;
else if (strncmp(pixel_t, "bayer_rggb12", size) == 0)
*format = V4L2_PIX_FMT_SRGGB12;
else if (strncmp(pixel_t, "bayer_wdr_pwl_rggb12", size) == 0)
else if (strncmp(pixel_t, "bayer_wdr_dol_rggb10", size) == 0)
else if (strncmp(pixel_t, "bayer_xbggr10p", size) == 0)
*format = V4L2_PIX_FMT_XBGGR10P;
else if (strncmp(pixel_t, "bayer_xrggb10p", size) == 0)
*format = V4L2_PIX_FMT_XRGGB10P;
else if (strncmp(pixel_t, "yuv_yuyv16", size) == 0)
*format = V4L2_PIX_FMT_YUYV;
else if (strncmp(pixel_t, "yuv_yvyu16", size) == 0)
*format = V4L2_PIX_FMT_YVYU;
else if (strncmp(pixel_t, "yuv_uyvy16", size) == 0)
*format = V4L2_PIX_FMT_UYVY;
else if (strncmp(pixel_t, "yuv_vyuy16", size) == 0)
*format = V4L2_PIX_FMT_VYUY;
else {
pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
return -EINVAL;
return 0;
