Hi everyone,
I use TX2 installed Jetpack4.6 I set F20 pin SDCARD_WP as input pin, but read data always high even the pin connect to gound. The pin mux in dts as below, how to fix this issue? thanks.
Hi Jerry,
I found that the D00 revision tx2 module works well, but D02 revision tx2 module can’t read low level. Are there any differences between the two modules? Thanks.
What do you mean the D00 and D02 module? Can you share a photo of two modules with part number?
