TX2 kernel shows error for LSI 92xx and m2 to usb2.0, how to?
I worked to add megaraid_sas.ko to support raid. Then it works.
But show errors in dmesg:
[ 53.748742] __arm_smmu_context_fault: 63219 callbacks suppressed
[ 53.748749] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x7ffff000, fsynr=0x210011, cb=21, sid=17(0x11 - AFI), pgd=0, pud=0, pmd=0, pte=0
and m2 to usb2.0 shows:
[ 54.356436] configfs-gadget gadget: Wrong NDP SIGN
and IRQ 67:
[ 48.928400] irq 67: nobody cared (try booting with the “irqpoll” option)
[ 48.935104] CPU: 0 PID: 4853 Comm: Xorg Not tainted 4.9.337 #2
[ 48.935107] Hardware name: quill (DT)
[ 48.935110] Call trace:
[ 48.935126] [<00000000d950525a>] dump_backtrace+0x0/0x198
[ 48.935133] [<00000000f4c186d3>] show_stack+0x24/0x30
[ 48.935141] [<00000000988583db>] dump_stack+0xa0/0xc4
[ 48.935148] [<000000008edf3188>] __report_bad_irq+0x3c/0xf8
[ 48.935152] [<0000000007a98ed9>] note_interrupt+0x2c8/0x318
[ 48.935157] [<000000004a9552d5>] handle_irq_event_percpu+0x4c/0x60
[ 48.935160] [<000000002594c58b>] handle_irq_event+0x50/0x80
[ 48.935165] [<0000000010bb4859>] handle_fasteoi_irq+0xd4/0x1c0
[ 48.935169] [<000000001d62565a>] generic_handle_irq+0x34/0x50
[ 48.935172] [<000000007a4ac3e5>] __handle_domain_irq+0x68/0xc0
[ 48.935176] [<000000000d804d27>] gic_handle_irq+0x5c/0xb0
[ 48.935179] [<00000000ba67e8aa>] el1_irq+0xe8/0x194
[ 48.935185] [<0000000057a79982>] irq_exit+0xd0/0x118
[ 48.935188] [<00000000dd7b4de3>] __handle_domain_irq+0x6c/0xc0
[ 48.935192] [<000000000d804d27>] gic_handle_irq+0x5c/0xb0
[ 48.935195] [<000000006312c36b>] el0_irq_naked+0x54/0x60
[ 48.935197] handlers:
[ 48.937470] [<00000000dc8ccfcb>] tegra_mcerr_hard_irq threaded [<000000006cd03dfa>] tegra_mcerr_thread
[ 48.946787] Disabling IRQ #67
kernel source from:
https://developer.nvidia.com/downloads/embedded/l4t/r32_release_v7.4/sources/t186/public_sources.tbz2
I tried but in most .config usb would all offline include wifi and usb3 port.
“irqpoll” causes kernel panic
Hardware works fine.
how to resolve? or disable the message?
We would suggest check back trace to debug further. Looks like the driver uses certain already-in-use IRQ and triggers the issue.
ok. The IRQ 67 is not mine. I will check menuconfig.
⋊> lucloner@ubuntu ⋊> ~ sudo lsusb 21:18:11
Bus 002 Device 002: ID 05e3:0626 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 007: ID 0bda:1a2b Realtek Semiconductor Corp.
Bus 001 Device 008: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
Bus 001 Device 006: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 004: ID 0483:5750 STMicroelectronics
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
⋊> lucloner@ubuntu ⋊> ~ sudo lspci -v 21:18:33
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 382
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 40100000-401fffff
Capabilities: [40] Subsystem: NVIDIA Corporation Device 0000
Capabilities: [48] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Capabilities: [80] Express Root Port (Slot+), MSI 00
Capabilities: [100] Advanced Error Reporting
Kernel driver in use: pcieport
01:00.0 RAID bus controller: LSI Logic / Symbios Logic MegaRAID SAS 2208 [Thunderbolt] (rev 03)
Subsystem: LSI Logic / Symbios Logic MegaRAID SAS 9265CV-8i / 9270CV-8i
I/O ports at 1000 [disabled] [size=256]
Memory at 40160000 (64-bit, non-prefetchable) [size=16K]
Memory at 40100000 (64-bit, non-prefetchable) [size=256K]
[virtual] Expansion ROM at 40140000 [disabled] [size=128K]
Capabilities: [50] Power Management version 3
Capabilities: [68] Express Endpoint, MSI 00
Capabilities: [d0] Vital Product Data
Capabilities: [a8] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [c0] MSI-X: Enable+ Count=16 Masked-
Capabilities: [1e0] #19
Capabilities: [1c0] Power Budgeting <?>
Capabilities: [190] #16
Capabilities: [148] Alternative Routing-ID Interpretation (ARI)
Kernel driver in use: megaraid_sas
Kernel modules: megaraid_sas
