While updating TX2 L4T version from R32.1 to R32.6.1,I got mipi csi2 video error:
[ 2983.642629] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2983.649357] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2983.862447] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2983.868843] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2984.082648] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2984.089364] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2984.306664] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2984.313411] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2984.526722] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2984.533427] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2984.746647] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2984.753289] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2984.966658] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2984.973199] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2985.186643] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2985.193315] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2985.406666] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2985.413329] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2985.626628] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2985.633179] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 2985.846701] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2985.853296] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
trace log as below,
kworker/4:1-11180 [004] .... 3229.912205: rtos_queue_send_from_isr_failed: tstamp:101196257824 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3229.912210: rtos_queue_send_from_isr_failed: tstamp:101196258285 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3229.912215: rtos_queue_send_from_isr_failed: tstamp:101196258743 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3229.912220: rtos_queue_send_from_isr_failed: tstamp:101196259214 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3229.912225: rtos_queue_send_from_isr_failed: tstamp:101196259679 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3229.912230: rtos_queue_send_from_isr_failed: tstamp:101196260260 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3229.912235: rtos_queue_send_failed: tstamp:101196263775 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3229.968049: rtos_queue_peek_from_isr_failed: tstamp:101198351245 queue:0x0b4b4940
vi-output, ov56-10780 [005] .... 3230.094223: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov56-10780 [005] .... 3230.094297: tegra_channel_capture_frame: sof:-549620698988.-268972636928
kworker/4:1-11180 [004] .... 3230.136059: rtos_queue_send_from_isr_failed: tstamp:101203084437 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.136076: rtos_queue_send_from_isr_failed: tstamp:101203084924 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.136081: rtos_queue_send_from_isr_failed: tstamp:101203085398 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.136086: rtos_queue_send_from_isr_failed: tstamp:101203085878 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.136091: rtos_queue_send_from_isr_failed: tstamp:101203086340 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.136097: rtos_queue_send_from_isr_failed: tstamp:101203086796 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.136102: rtos_queue_send_from_isr_failed: tstamp:101203087255 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.136108: rtos_queue_send_from_isr_failed: tstamp:101203087713 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.136115: rtos_queue_send_failed: tstamp:101203089848 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.136122: rtos_queue_send_from_isr_failed: tstamp:101203096758 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.136128: rtos_queue_send_from_isr_failed: tstamp:101203097219 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.136134: rtos_queue_send_from_isr_failed: tstamp:101203097673 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.136139: rtos_queue_send_from_isr_failed: tstamp:101203098137 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.136144: rtos_queue_send_from_isr_failed: tstamp:101203098626 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.136149: rtos_queue_send_from_isr_failed: tstamp:101203099083 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.136154: rtos_queue_send_from_isr_failed: tstamp:101203099533 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.136159: rtos_queue_send_from_isr_failed: tstamp:101203099987 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.136164: rtos_queue_send_failed: tstamp:101203102067 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.136169: rtos_queue_send_from_isr_failed: tstamp:101203116906 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.136174: rtos_queue_send_from_isr_failed: tstamp:101203117523 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.136179: rtos_queue_send_from_isr_failed: tstamp:101203117977 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.136184: rtos_queue_send_from_isr_failed: tstamp:101203118434 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.136189: rtos_queue_send_from_isr_failed: tstamp:101203118895 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.136194: rtos_queue_send_from_isr_failed: tstamp:101203119345 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.136199: rtos_queue_send_from_isr_failed: tstamp:101203119798 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.136205: rtos_queue_send_from_isr_failed: tstamp:101203120270 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.136210: rtos_queue_send_failed: tstamp:101203122124 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.136215: rtos_queue_send_from_isr_failed: tstamp:101203128156 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.136220: rtos_queue_send_from_isr_failed: tstamp:101203128618 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.136225: rtos_queue_send_from_isr_failed: tstamp:101203129103 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.136232: rtos_queue_send_from_isr_failed: tstamp:101203129563 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.136237: rtos_queue_send_from_isr_failed: tstamp:101203130018 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.136242: rtos_queue_send_from_isr_failed: tstamp:101203130472 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.136248: rtos_queue_send_from_isr_failed: tstamp:101203130941 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.136253: rtos_queue_send_from_isr_failed: tstamp:101203131411 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.136258: rtos_queue_send_failed: tstamp:101203137409 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.136267: rtos_queue_peek_from_isr_failed: tstamp:101203350981 queue:0x0b4b4940
kworker/4:1-11180 [004] .... 3230.308025: rtos_queue_peek_from_isr_failed: tstamp:101208351145 queue:0x0b4b4940
vi-output, ov56-10780 [005] .... 3230.316835: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov56-10780 [005] .... 3230.316879: tegra_channel_capture_frame: sof:-549620698988.-268972636928
kworker/4:1-11180 [004] .... 3230.364039: rtos_queue_send_from_isr_failed: tstamp:101209966772 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.364054: rtos_queue_send_from_isr_failed: tstamp:101209967254 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.364062: rtos_queue_send_from_isr_failed: tstamp:101209967715 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.364067: rtos_queue_send_from_isr_failed: tstamp:101209968183 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.364072: rtos_queue_send_from_isr_failed: tstamp:101209968644 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.364077: rtos_queue_send_from_isr_failed: tstamp:101209969101 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.364083: rtos_queue_send_from_isr_failed: tstamp:101209969559 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.364088: rtos_queue_send_from_isr_failed: tstamp:101209970045 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.364096: rtos_queue_send_failed: tstamp:101209972310 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.364101: rtos_queue_send_from_isr_failed: tstamp:101210079208 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.364108: rtos_queue_send_from_isr_failed: tstamp:101210079492 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.364113: rtos_queue_send_from_isr_failed: tstamp:101210079762 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.364118: rtos_queue_send_from_isr_failed: tstamp:101210080028 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.364124: rtos_queue_send_from_isr_failed: tstamp:101210080300 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.364129: rtos_queue_send_from_isr_failed: tstamp:101210080566 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.364134: rtos_queue_send_from_isr_failed: tstamp:101210080832 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.364139: rtos_queue_send_from_isr_failed: tstamp:101210081103 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.364144: rtos_queue_send_failed: tstamp:101210081896 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.364150: rtos_queue_send_from_isr_failed: tstamp:101210088617 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.364155: rtos_queue_send_from_isr_failed: tstamp:101210088793 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.364160: rtos_queue_send_from_isr_failed: tstamp:101210088968 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.364165: rtos_queue_send_from_isr_failed: tstamp:101210089146 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.364171: rtos_queue_send_from_isr_failed: tstamp:101210089321 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.364176: rtos_queue_send_from_isr_failed: tstamp:101210089528 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.364181: rtos_queue_send_from_isr_failed: tstamp:101210089702 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.364186: rtos_queue_send_from_isr_failed: tstamp:101210089878 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.364191: rtos_queue_send_failed: tstamp:101210090640 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.364196: rtos_queue_send_from_isr_failed: tstamp:101210093382 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.364201: rtos_queue_send_from_isr_failed: tstamp:101210093560 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.364206: rtos_queue_send_from_isr_failed: tstamp:101210093736 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.364211: rtos_queue_send_from_isr_failed: tstamp:101210093911 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.364217: rtos_queue_send_from_isr_failed: tstamp:101210094086 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.364222: rtos_queue_send_from_isr_failed: tstamp:101210094260 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.364227: rtos_queue_send_from_isr_failed: tstamp:101210094434 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.364231: rtos_queue_send_from_isr_failed: tstamp:101210094606 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.364236: rtos_queue_send_failed: tstamp:101210096505 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.476040: rtos_queue_peek_from_isr_failed: tstamp:101213351158 queue:0x0b4b4940
vi-output, ov56-10780 [005] .... 3230.538201: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, ov56-10780 [005] .... 3230.538258: tegra_channel_capture_frame: sof:-549620698988.-268972636928
kworker/4:1-11180 [004] .... 3230.588027: rtos_queue_send_from_isr_failed: tstamp:101216959726 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.588038: rtos_queue_send_from_isr_failed: tstamp:101216960225 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.588043: rtos_queue_send_from_isr_failed: tstamp:101216960713 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.588048: rtos_queue_send_from_isr_failed: tstamp:101216961172 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.588053: rtos_queue_send_from_isr_failed: tstamp:101216961632 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.588060: rtos_queue_send_from_isr_failed: tstamp:101216962100 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.588066: rtos_queue_send_from_isr_failed: tstamp:101216962553 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.588070: rtos_queue_send_from_isr_failed: tstamp:101216963007 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.588080: rtos_queue_send_failed: tstamp:101216965273 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.588085: rtos_queue_send_from_isr_failed: tstamp:101216973772 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.588089: rtos_queue_send_from_isr_failed: tstamp:101216974228 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.588094: rtos_queue_send_from_isr_failed: tstamp:101216974683 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.588102: rtos_queue_send_from_isr_failed: tstamp:101216975137 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.588117: rtos_queue_send_from_isr_failed: tstamp:101216975597 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.588124: rtos_queue_send_from_isr_failed: tstamp:101216976054 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.588130: rtos_queue_send_from_isr_failed: tstamp:101216976506 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.588135: rtos_queue_send_from_isr_failed: tstamp:101216976963 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.588140: rtos_queue_send_failed: tstamp:101216978887 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.588146: rtos_queue_send_from_isr_failed: tstamp:101216991335 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.588152: rtos_queue_send_from_isr_failed: tstamp:101216991819 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.588156: rtos_queue_send_from_isr_failed: tstamp:101216992283 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.588162: rtos_queue_send_from_isr_failed: tstamp:101216992747 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.588167: rtos_queue_send_from_isr_failed: tstamp:101216993208 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.588172: rtos_queue_send_from_isr_failed: tstamp:101216993661 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.588177: rtos_queue_send_from_isr_failed: tstamp:101216994121 queue:0x0b4b1298
kworker/4:1-11180 [004] .... 3230.588182: rtos_queue_send_from_isr_failed: tstamp:101216994581 queue:0x0b4b2058
kworker/4:1-11180 [004] .... 3230.588188: rtos_queue_send_failed: tstamp:101216996667 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.588193: rtos_queue_send_from_isr_failed: tstamp:101217002781 queue:0x0b4a7698
kworker/4:1-11180 [004] .... 3230.588199: rtos_queue_send_from_isr_failed: tstamp:101217003381 queue:0x0b4ab1a8
kworker/4:1-11180 [004] .... 3230.588204: rtos_queue_send_from_isr_failed: tstamp:101217003847 queue:0x0b4acdd8
kworker/4:1-11180 [004] .... 3230.588209: rtos_queue_send_from_isr_failed: tstamp:101217004302 queue:0x0b4ae958
kworker/4:1-11180 [004] .... 3230.588214: rtos_queue_send_from_isr_failed: tstamp:101217004757 queue:0x0b4af718
kworker/4:1-11180 [004] .... 3230.588219: rtos_queue_send_from_isr_failed: tstamp:101217005211 queue:0x0b4b04d8
kworker/4:1-11180 [004] .... 3230.588224: rtos_queue_send_from_isr_failed: tstamp:101217005671 queue:0x0b4b1298
mipi signal source is same one.
