Dear WayneWWW,
Here is full log
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (gcc version 4.8.5 (GCC) ) #24 SMP PREEMPT Wed Jun 17 16:23:04 KST 2020
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options '')
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 16 pages/cpu @ffffffc1f5fa0000 s27264 r8192 d30080 u65536
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=1424319078671 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7978212K/8208384K available (10200K kernel code, 1407K rwdata, 5268K rodata, 1008K init, 681K bss, 164636K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
[ 0.000000] .init : 0xffffffc000f9c000 - 0xffffffc001098000 ( 1008 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc000f9c000 ( 15472 KB)
[ 0.000000] .data : 0xffffffc0010b8000 - 0xffffffc001217c40 ( 1408 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009957] Console: colour dummy device 80x25
[ 0.014620] console [tty0] enabled
[ 0.018177] bootconsole [uart0] disabled
[ 0.022281] kmemleak: Kernel memory leak detector disabled
[ 0.022295] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.022308] pid_max: default: 32768 minimum: 301
[ 0.022363] Security Framework initialized
[ 0.022398] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022409] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022795] Initializing cgroup subsys io
[ 0.022809] Initializing cgroup subsys memory
[ 0.022830] Initializing cgroup subsys devices
[ 0.022841] Initializing cgroup subsys freezer
[ 0.022851] Initializing cgroup subsys net_cls
[ 0.022860] Initializing cgroup subsys perf_event
[ 0.022870] Initializing cgroup subsys net_prio
[ 0.022883] Initializing cgroup subsys pids
[ 0.022892] Initializing cgroup subsys debug
[ 0.023047] CPU0 ipc=752
[ 0.023060] CPU1 ipc=1024
[ 0.023068] CPU2 ipc=1024
[ 0.023077] CPU3 ipc=752
[ 0.023087] CPU4 ipc=752
[ 0.023098] CPU5 ipc=752
[ 0.023130] ASID allocator initialised with 65536 entries
[ 0.046953] tegra-id: chipid=21817.
[ 0.046975] tegra-id: opt_subrevision=1.
[ 0.046989] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.047688] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.047711] DTB Build time: Jun 17 2020 16:22:30
[ 0.062553] CPU1: Booted secondary processor [4e0f0030]
[ 0.074030] CPU2: Booted secondary processor [4e0f0030]
[ 0.085664] CPU3: Booted secondary processor [411fd073]
[ 0.097666] CPU4: Booted secondary processor [411fd073]
[ 0.109666] CPU5: Booted secondary processor [411fd073]
[ 0.109734] Brought up 6 CPUs
[ 0.109794] SMP: Total of 6 processors activated.
[ 0.109809] CPU: All CPU(s) started at EL2
[ 0.110241] devtmpfs: initialized
[ 0.137506] Initilizing CustomIPI irq domain
[ 0.137729] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.138546] pinctrl core: initialized pinctrl subsystem
[ 0.138747] OS set in device tree is not L4T.
[ 0.138960] regulator-dummy: no parameters
[ 0.139077] Initializing plugin-manager
[ 0.139138] Plugin module not found
[ 0.139552] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139905] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.140529] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141711] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.142096] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.142361] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.142580] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.143004] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.143455] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143736] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.144114] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.144367] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.144590] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144856] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.146806] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.148741] Adding domain adsp-pd to PM domain ape-pd
[ 0.151261] NET: Registered protocol family 16
[ 0.152162] console [pstore-1] enabled
[ 0.152176] pstore: Registered ramoops as persistent store backend
[ 0.152190] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.157664] cpuidle: using governor ladder
[ 0.165662] cpuidle: using governor menu
[ 0.167003] bpmp: waiting for handshake
[ 0.167019] bpmp: handshake completed
[ 0.167066] bpmp: synchronizing channels
[ 0.167084] bpmp: channels synchronized
[ 0.167095] bpmp: mail init ok
[ 0.167414] vdso: 2 pages (1 code @ ffffffc0010bd000, 1 data @ ffffffc0010bc000)
[ 0.167448] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168384] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169898] tegra_powergate_init: DONE
[ 0.169924] DTS File Name: ../arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169946] DTB Build time: Jun 17 2020 16:22:30
[ 0.171065] Tegra reboot handler registered.
[ 0.172365] Registering Tegra186 clocks (this may take a while)...done
[ 0.174093] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.174115] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.174129] arm-smmu 12000000.iommu: stage 1 translation
[ 0.174142] arm-smmu 12000000.iommu: stage 2 translation
[ 0.174155] arm-smmu 12000000.iommu: nested translation
[ 0.174171] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.174191] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.174210] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.174225] arm-smmu 12000000.iommu: Stage-1: 39-bit VA -> 48-bit IPA
[ 0.174239] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA -> 48-bit PA
[ 0.223744] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.229026] iommu: Adding device 3460000.sdhci to group 0
[ 0.229968] iommu: Adding device 3400000.sdhci to group 1
[ 0.233684] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.234166] iommu: Adding device 3160000.i2c to group 3
[ 0.234598] iommu: Adding device c240000.i2c to group 4
[ 0.235004] iommu: Adding device 3180000.i2c to group 5
[ 0.235434] iommu: Adding device 3190000.i2c to group 6
[ 0.235883] iommu: Adding device 31b0000.i2c to group 7
[ 0.236218] iommu: Adding device 31c0000.i2c to group 8
[ 0.236544] iommu: Adding device c250000.i2c to group 9
[ 0.236868] iommu: Adding device 31e0000.i2c to group 10
[ 0.238879] iommu: Adding device 3210000.spi to group 11
[ 0.239251] iommu: Adding device c260000.spi to group 12
[ 0.239597] iommu: Adding device 3240000.spi to group 13
[ 0.240392] iommu: Adding device 3100000.serial to group 14
[ 0.240700] iommu: Adding device 3110000.serial to group 15
[ 0.241025] iommu: Adding device c280000.serial to group 16
[ 0.241321] iommu: Adding device 3130000.serial to group 17
[ 0.242646] iommu: Adding device 2490000.ether_qos to group 18
[ 0.243312] iommu: Adding device b000000.rtcpu to group 19
[ 0.243833] iommu: Adding device c1a0000.aon to group 20
[ 0.244786] Wake73 for irq=42
[ 0.245149] iommu: Adding device smmu_test to group 21
[ 0.245700] mc: mapped MMIO address: 0xffffff8000560000 -> 0x2c10000
[ 0.245742] mc: mapped MMIO address: 0xffffff8000640000 -> 0x2c20000
[ 0.245779] mc: mapped MMIO address: 0xffffff8000660000 -> 0x2c30000
[ 0.245816] mc: mapped MMIO address: 0xffffff8000fa0000 -> 0x2c40000
[ 0.245867] mc: mapped MMIO address: 0xffffff8000fc0000 -> 0x2c50000
[ 0.245927] mc-err: Set intmask: 0xf3140
[ 0.246171] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.247077] Wake76 for irq=199
[ 0.247101] Wake77 for irq=199
[ 0.247151] Wake78 for irq=199
[ 0.247171] Wake79 for irq=199
[ 0.247191] Wake80 for irq=199
[ 0.247210] Wake81 for irq=199
[ 0.247229] Wake82 for irq=199
[ 0.247356] iommu: Adding device 3530000.xhci to group 22
[ 0.247742] iommu: Adding device 3550000.xudc to group 23
[ 0.248565] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.248597] tegra-pmc: ### PMC reset source: Power on reset
[ 0.248621] tegra-pmc: ### PMC reset level: L0
[ 0.248661] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.248919] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.248957] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.249158] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.249188] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.249681] iommu: Adding device 13e10000.host1x to group 24
[ 0.249982] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.250230] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.250484] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.250764] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.251034] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.251272] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.251545] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.251808] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.252227] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.252800] iommu: Adding device 15700000.vi to group 34
[ 0.253141] iommu: Adding device 15600000.isp to group 35
[ 0.253555] iommu: Adding device 15200000.nvdisplay to group 36
[ 0.253891] iommu: Adding device 15210000.nvdisplay to group 37
[ 0.254266] iommu: Adding device 15340000.vic to group 38
[ 0.254516] iommu: Adding device 154c0000.nvenc to group 39
[ 0.254763] iommu: Adding device 15480000.nvdec to group 40
[ 0.255084] iommu: Adding device 15380000.nvjpg to group 41
[ 0.255321] iommu: Adding device 15500000.tsec to group 42
[ 0.255575] iommu: Adding device 15100000.tsecb to group 43
[ 0.256284] iommu: Adding device 15810000.se to group 44
[ 0.256502] iommu: Adding device 15820000.se to group 45
[ 0.256735] iommu: Adding device 15830000.se to group 46
[ 0.256924] iommu: Adding device 15840000.se to group 47
[ 0.257488] iommu: Adding device 17000000.gp10b to group 48
[ 0.259020] tegra-reset 5000000.clock: registered 193 resets.
[ 0.261188] iommu: Adding device d000000.bpmp to group 49
[ 0.261425] bpmp: ping status is 0
[ 0.261624] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.262002] bpmp d000000.bpmp: probe ok
[ 0.264938] iommu: Adding device 2600000.dma to group 50
[ 0.266083] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.266146] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.266229] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.266284] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.266343] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.266399] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.266475] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.266618] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.268607] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.268734] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.269689] iommu: Adding device 10003000.pcie-controller to group 51
[ 0.269965] iommu: Adding device sound to group 52
[ 0.271751] iommu: Adding device 3510000.hda to group 53
[ 0.272932] iommu: Adding device adsp_audio to group 54
[ 0.274395] iommu: Adding device 2993000.adsp to group 55
[ 0.284240] vdd-ac-bat: 5000 mV
[ 0.286461] vdd-1v8-ap: 1800 mV
[ 0.303870] max96755_i2c_client_init: called
[ 0.304732] SCSI subsystem initialized
[ 0.305087] usbcore: registered new interface driver usbfs
[ 0.305154] usbcore: registered new interface driver hub
[ 0.305286] usbcore: registered new device driver usb
[ 0.307492] lcd_driver 0-0040: of_dsi2gmsl_parse_platform_data: gpio number not provided
[ 0.307557] max96755_i2c_probe: returning 0
[ 0.307864] lcd_driver 0-0040: success to i2c comm, addr : 40 CMD[0x000d] ret:2
[ 0.307902] lcd_i2c_initial_set des chip id : 0x71
[ 0.308195] lcd_driver 0-0040: success to i2c comm, addr : 40 CMD[0x0013] ret:2
[ 0.308232] lcd_i2c_initial_set ser lock check : 71, result : 2
[ 0.308261] lcd_i2c_initial_set GMSL2 link failed
[ 0.308317] i2c i2c-0: Failed to register i2c client ina3221x at 0x40 (-16)
[ 0.308343] i2c i2c-0: of_i2c: Failure registering /i2c@3160000/ina3221x@40
[ 0.308937] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.309136] pca953x 0-0074: failed reading register
[ 0.309243] pca953x: probe of 0-0074 failed with error -121
[ 0.309642] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.309865] pca953x 0-0077: failed reading register
[ 0.309955] pca953x: probe of 0-0077 failed with error -121
[ 0.320957] media: Linux media interface: v0.10
[ 0.321086] Linux video capture interface: v2.00
[ 0.321151] pps_core: LinuxPPS API ver. 1 registered
[ 0.321197] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.321262] PTP clock support registered
[ 0.322250] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 25 sec
[ 0.322328] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.323895] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.326021] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.326207] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.326304] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.330721] vddio-ddr: at 1125 mV
[ 0.334554] avdd_dsi_csi: 1200 mV
[ 0.338560] vdd-1v8: 1800 mV
[ 0.342554] vdd-3v3-sys: 3300 mV
[ 0.343627] spmic-ldo0: at 1800 mV
[ 0.344417] spmic-ldo1: at 800 mV
[ 0.346556] vddio-3v3: 3300 mV
[ 0.347208] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.350558] vdd-rtc: at 800 mV
[ 0.351363] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[ 0.354556] spmic-ldo6: at 1500 mV
[ 0.358556] vdd-pex-1v05: 1000 mV
[ 0.359182] dvdd-pex: 1000 mV
[ 0.359500] max77620 4-003c: max77620 probe successful
[ 0.359789] Advanced Linux Sound Architecture Driver Initialized.
[ 0.360898] en-vdd-sd: 3300 mV
[ 0.361210] vdd-usb0-5v: 5000 mV
[ 0.361392] vdd-usb1-5v: 5000 mV
[ 0.361785] vdd-3v3: 3300 mV
[ 0.361944] en-vdd-vcm-2v8: 2800 mV
[ 0.362094] vdd-sys-bl: 3300 mV
[ 0.365674] extcon-gpio-states external-connection:extcon@1: Cable state 1
[ 0.366097] clocksource: Switched to clocksource arch_sys_counter
[ 0.366383] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.366562] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.367036] nvmap_page_pool_init: Total RAM pages: 2010937
[ 0.367054] nvmap_page_pool_init: nvmap page pool size: 251367 pages (981 MB)
[ 0.367209] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.371861] Wake76 for irq=199
[ 0.371875] Wake77 for irq=199
[ 0.371886] Wake78 for irq=199
[ 0.371896] Wake79 for irq=199
[ 0.371907] Wake80 for irq=199
[ 0.371916] Wake81 for irq=199
[ 0.371926] Wake82 for irq=199
[ 0.372764] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.372982] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.373385] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.373467] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.373619] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.373763] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.373926] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.374247] isomgr_init(): iso emc max clk=1866000KHz
[ 0.374261] isomgr_init(): max_iso_bw=26870400KB
[ 0.374357] NET: Registered protocol family 2
[ 0.374720] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.374928] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.375246] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.375308] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.375364] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.375527] NET: Registered protocol family 1
[ 0.375722] RPC: Registered named UNIX socket transport module.
[ 0.375741] RPC: Registered udp transport module.
[ 0.375752] RPC: Registered tcp transport module.
[ 0.375764] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.375895] Trying to unpack rootfs image as initramfs...
[ 0.390412] host1x 13e10000.host1x: initialized
[ 0.391285] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.393168] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.393279] audit: initializing netlink subsys (disabled)
[ 0.393312] audit: type=2000 audit(0.380:1): initialized
[ 0.400272] io scheduler noop registered
[ 0.400386] io scheduler cfq registered (default)
[ 0.403358] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.404600] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.405666] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.406724] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.410526] tsec 15500000.tsec: initialized
[ 0.411725] tsec 15100000.tsecb: initialized
[ 0.414252] nvdec 15480000.nvdec: initialized
[ 0.418074] falcon 15340000.vic: initialized
[ 0.419131] falcon 154c0000.nvenc: initialized
[ 0.420158] falcon 15380000.nvjpg: initialized
[ 0.420920] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.421420] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.421915] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.422432] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.422930] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.423428] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.423928] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.424426] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.425909] OF_DC_LOG: dc or node /host1x/dsi
[ 0.425924] DC OR NODE connected to /host1x/dsi
[ 0.425987] [test] nvdisp_stub
[ 0.426007] OF_DC_LOG: fb bpp 32
[ 0.426018] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.426036] OF_DC_LOG: fb flip on probe
[ 0.426101] [test] nvdisp_stub
[ 0.426117] OF_DC_LOG: dsi controller vs DSI_VS_1
[ 0.426129] OF_DC_LOG: Enable hs clock in lp mode 1
[ 0.426139] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.426144] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.426173] OF_DC_LOG: n data lanes 4
[ 0.426184] OF_DC_LOG: dsi video NONE_BURST_MODE_WITH_SYNC_END
[ 0.426196] OF_DC_LOG: dsi pixel format 24BIT_P
[ 0.426207] OF_DC_LOG: dsi refresh rate 60
[ 0.426222] OF_DC_LOG: dsi virtual channel 0
[ 0.426232] OF_DC_LOG: dsi instance 0
[ 0.426244] OF_DC_LOG: dsi panel reset 0
[ 0.426271] OF_DC_LOG: dsi2gmsl_bridge_enable 1
[ 0.426286] OF_DC_LOG: dsi power saving suspend 0
[ 0.426297] OF_DC_LOG: dsi ulpm_not_supported 0
[ 0.426308] OF_DC_LOG: dsi video type VIDEO_MODE
[ 0.426319] OF_DC_LOG: dsi video clock mode CONTINUOUS
[ 0.426340] OF_DC_LOG: suspend stop stream late 0
[ 0.426375] OF_DC_LOG: boardinfo platform_boardid = 0 platform_boardversion = 0 display_boardid = 0 display_boardversion = 0
[ 0.426419] OF_DC_LOG: out_width 230
[ 0.426432] OF_DC_LOG: out_height 143
[ 0.426453] OF_DC_LOG: default_out flag 0
[ 0.426469] OF_DC_LOG: parent clk pll_d
[ 0.426483] OF_DC_LOG: framebuffer xres 1280
[ 0.426494] OF_DC_LOG: framebuffer yres 720
[ 0.426534] OF_DC_LOG: nvidia,sd-enable 0
[ 0.426575] OF_DC_LOG: nvidia,coeff 0 0 0
[ 0.426586] OF_DC_LOG: nvidia,fc 0 0
[ 0.426596] OF_DC_LOG: nvidia,blp 0 0
[ 0.426607] OF_DC_LOG: nvidia,bias0 default
[ 0.426618] OF_DC_LOG: of pclk 64022400
[ 0.426734] OF_DC_LOG: panel csc 0xd581
[ 0.426745] OF_DC_LOG: panel csc 0x2979
[ 0.426754] OF_DC_LOG: panel csc 0xc5
[ 0.426764] OF_DC_LOG: panel csc 0x0
[ 0.426775] OF_DC_LOG: panel csc 0x831
[ 0.426785] OF_DC_LOG: panel csc 0xcac1
[ 0.426796] OF_DC_LOG: panel csc 0x20c
[ 0.426806] OF_DC_LOG: panel csc 0x0
[ 0.426816] OF_DC_LOG: panel csc 0x189
[ 0.426826] OF_DC_LOG: panel csc 0x625
[ 0.426836] OF_DC_LOG: panel csc 0xcc4a
[ 0.426846] OF_DC_LOG: panel csc 0x0
[ 0.426859] OF_DC_LOG: dc flag 1
[ 0.426869] OF_DC_LOG: dc controller index 0
[ 0.426882] OF_DC_LOG: fb window Index 0
[ 0.426893] OF_DC_LOG: win mask 0x7
[ 0.426904] OF_DC_LOG: cmu enable 1
[ 0.426918] tegradc 15200000.nvdisplay: DT parsed successfully
[ 0.426948] tegradc 15200000.nvdisplay: Display dc.ffffff80025e0000 registered with id=0
[ 0.433451] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.434928] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.434952] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.434969] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.435021] tegradc 15200000.nvdisplay: vblank syncpt # 7 for dc 0
[ 0.435037] tegradc 15200000.nvdisplay: vpulse3 syncpt # 8 for dc 0
[ 0.435380] tegradc 15200000.nvdisplay: tegra_dc_set_out, out->type : 2
[ 0.435396] tegradc 15200000.nvdisplay: dsi: tegra_dc_dsi_init
[ 0.435442] tegradc 15200000.nvdisplay: dsi: _tegra_dc_dsi_init
[ 0.436113] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.436433] tegradc 15200000.nvdisplay: dsi: __tegra_dc_dsi_init
[ 0.436518] tegradc 15200000.nvdisplay: dsi: init tegra_dsi2gmsl_ops
[ 0.436661] kfuse 3830000.kfuse: initialized
[ 0.438168] tegradc 15200000.nvdisplay: probed
[ 0.438471] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.438958] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.440959] console [ttyS0] disabled
[ 0.441015] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.765240] console [ttyS0] enabled
[ 2.767300] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.768371] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.768574] serial-tegra 3130000.serial: RX in PIO mode
[ 2.769469] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.771604] Console: switching to colour frame buffer device 160x45
[ 2.779311] brd: module loaded
[ 2.783660] loop: module loaded
[ 2.783895] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.783900] nct1008_nct72 7-004c: starting parse dt
[ 2.783992] nct1008_nct72 7-004c: success parsing dt
[ 2.784118] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.797477] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.820858] tmp451: Enabled overheat logging at 104.00C
[ 2.821004] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.823385] THERMAL EST: found 3 subdevs
[ 2.823390] THERMAL EST num_resources: 0
[ 2.823394] [THERMAL EST subdev 0]
[ 2.823398] [THERMAL EST subdev 1]
[ 2.823402] [THERMAL EST subdev 2]
[ 2.823702] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.823705] THERMAL EST: thz register success.
[ 2.823811] THERMAL EST: end of probe, return err: 0
[ 2.823861] tegra_profiler: Branch: Dev
[ 2.823864] tegra_profiler: Version: 1.117
[ 2.823866] tegra_profiler: Samples version: 41
[ 2.823867] tegra_profiler: IO version: 22
[ 2.823875] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.823881] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.823885] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.823889] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.823893] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.823896] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.823900] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.823903] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.823906] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.823910] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.823913] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.823917] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.824092] tegra_profiler: auth: init
[ 2.827491] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.827502] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.828427] scsi host0: tegra_ahci
[ 2.828782] scsi host1: tegra_ahci
[ 2.828911] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.828914] ata2: DUMMY
[ 2.829779] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.830252] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.830653] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.831481] tun: Universal TUN/TAP device driver, 1.6
[ 2.831483] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.831660] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.831662] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.831701] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.831703] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.832752] PPP generic driver version 2.4.2
[ 2.832881] PPP BSD Compression module registered
[ 2.832890] PPP Deflate Compression module registered
[ 2.832915] PPP MPPE Compression module registered
[ 2.832930] NET: Registered protocol family 24
[ 2.832993] usbcore: registered new interface driver r8152
[ 2.833028] usbcore: registered new interface driver asix
[ 2.833056] usbcore: registered new interface driver ax88179_178a
[ 2.833080] usbcore: registered new interface driver cdc_ether
[ 2.833114] usbcore: registered new interface driver smsc75xx
[ 2.833143] usbcore: registered new interface driver net1080
[ 2.833168] usbcore: registered new interface driver cdc_subset
[ 2.833193] usbcore: registered new interface driver zaurus
[ 2.833237] usbcore: registered new interface driver cdc_ncm
[ 2.833461] Wake76 for irq=199
[ 2.833464] Wake77 for irq=199
[ 2.833468] Wake78 for irq=199
[ 2.833470] Wake79 for irq=199
[ 2.833471] Wake80 for irq=199
[ 2.833473] Wake81 for irq=199
[ 2.833475] Wake82 for irq=199
[ 2.833531] tegra-xotg xotg: usb2 phy is not available yet
[ 2.834324] usbcore: registered new interface driver cdc_acm
[ 2.834327] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.834366] usbcore: registered new interface driver usb-storage
[ 2.834426] usbcore: registered new interface driver usbserial
[ 2.834449] usbcore: registered new interface driver cp210x
[ 2.834473] usbserial: USB Serial support registered for cp210x
[ 2.834495] usbcore: registered new interface driver ftdi_sio
[ 2.834515] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.834537] usbcore: registered new interface driver option
[ 2.834555] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.834580] usbcore: registered new interface driver pl2303
[ 2.834598] usbserial: USB Serial support registered for pl2303
[ 2.834805] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.853535] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b f7 18 b3
[ 2.854109] libphy: dwc_phy: probed
[ 2.854933] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.919249] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.987280] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.989411] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.989424] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.989565] i2c /dev entries driver
[ 2.990380] gspca_main: v2.14.0 registered
[ 2.990427] usbcore: registered new interface driver gspca_zc3xx
[ 2.990675] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.992583] FAN: coudln't get the regulator
[ 2.993311] device-mapper: uevent: version 1.0.3
[ 2.993504] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.993902] sdhci: Secure Digital Host Controller Interface driver
[ 2.993903] sdhci: Copyright(c) Pierre Ossman
[ 2.993908] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.012068] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 3.012466] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 3.012704] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 3.012769] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 3.012976] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.014465] usbcore: registered new interface driver usbhid
[ 3.014466] usbhid: USB HID core driver
[ 3.017539] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 3.017913] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 3.018082] ina3221x: probe of 0-0043 failed with error -121
[ 3.018645] nvadsp 2993000.adsp: in probe()...
[ 3.020027] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 3.020065] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 3.020313] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 3.032759] Denver: backdoor interface is NOT available.
[ 3.034161] Module initialized successfully
[ 3.038274] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 3.039984] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 3.040250] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 3.040638] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.040690] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 3.040738] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 3.040778] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 3.040827] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 3.040867] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 3.040907] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 3.041076] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 3.041078] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.041778] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 3.041781] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 3.041784] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 3.041786] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 3.041788] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 3.041791] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 3.041793] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 3.041831] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 3.046634] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 3.047507] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 3.047632] camchar: rtcpu character device driver loaded
[ 3.052837] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 3.053275] register_ari_mca_banks: Registered MCA ROC:IOB
[ 3.053540] register_ari_mca_banks: Registered MCA ROC:CCE
[ 3.054100] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.054394] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 3.054428] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 3.054469] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 3.054526] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 3.054555] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 3.054587] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 3.054613] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 3.054639] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 3.054666] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 3.054697] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 3.054720] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 3.054747] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 3.054749] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 3.054841] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 3.054872] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 3.054917] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 3.054947] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 3.055014] **** A57 ECC: Enabled
[ 3.055017] tegra18_a57_serr_init: on CPU 4 a A57 Core
[ 3.055190] parse_throttle_dt_data: Num cap clks = 4
[ 3.055193] parse_throttle_dt_data: clk=mcpu type=1
[ 3.055195] parse_throttle_dt_data: clk=bcpu type=2
[ 3.055204] parse_throttle_dt_data: clk=gpu type=4
[ 3.055206] parse_throttle_dt_data: clk=emc type=3
[ 3.056027] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.056154] tegra18x_actmon d230000.actmon: in actmon_register()...
[ 3.061563] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 3.063556] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 3.094078] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.094375] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 3.094432] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 3.094515] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 3.094546] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 257
[ 3.094785] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 3.100388] mmc0: MAN_BKOPS_EN bit is not set
[ 3.110028] mmc0: Skipping tuning since strobe enabled
[ 3.118023] mmc0: periodic cache flush enabled
[ 3.118030] mmc0: new HS400 MMC card at address 0001
[ 3.118378] mmcblk0: mmc0:0001 DG4032 29.1 GiB
[ 3.118565] mmcblk0boot0: mmc0:0001 DG4032 partition 1 4.00 MiB
[ 3.118720] mmcblk0boot1: mmc0:0001 DG4032 partition 2 4.00 MiB
[ 3.118879] mmcblk0rpmb: mmc0:0001 DG4032 partition 3 4.00 MiB
[ 3.120309] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 3.138162] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 3.150103] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.162498] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.360295] mmc1 tuning done saved tap delay=63
[ 3.360299] mmc1: hw tuning done ...
[ 3.360308] mmc1: tuning_window[0]: 0xffffffff
[ 3.360314] mmc1: tuning_window[1]: 0xfffff8ff
[ 3.360320] mmc1: tuning_window[2]: 0xff8fffff
[ 3.360325] mmc1: tuning_window[3]: 0x7fffffff
[ 3.360330] mmc1: tuning_window[4]: 0x0
[ 3.360336] mmc1: tuning_window[5]: 0x0
[ 3.360341] mmc1: tuning_window[6]: 0x0
[ 3.360346] mmc1: tuning_window[7]: 0x0
[ 3.360350] sdhci: Tap value: 63 | Trim value: 5
[ 3.360354] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.366517] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.366551] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.238723] tegradc 15200000.nvdisplay: fb registered
[ 4.245095] PD DISP0 index2 UP
[ 4.250330] PD DISP1 index3 UP
[ 4.258471] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e00e0
[ 4.266202] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0004
[ 4.273899] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e00a0
[ 4.281571] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e00e8
[ 4.289211] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e00ec
[ 4.296803] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e00e4
[ 4.304355] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e00e0
[ 4.311904] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0100
[ 4.319445] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1390
[ 4.326986] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e101c
[ 4.334492] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1020
[ 4.341972] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1028
[ 4.349433] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1024
[ 4.356873] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1394
[ 4.364299] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e13bc
[ 4.371715] [test] tegra_dc_readl: dc->base + reg * 4 = ffffff80025e0140
[ 4.379042] [test] tegra_dc_readl: dc->base + reg * 4 = ffffff80025e10d0
[ 4.386366] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e10d0
[ 4.393783] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0104
[ 4.401140] [test] tegra_dc_readl: dc->base + reg * 4 = ffffff80025e0104
[ 4.408409] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0104
[ 4.415715] [test] tegra_dc_readl: dc->base + reg * 4 = ffffff80025e0104
[ 4.422929] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1014
[ 4.430222] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0104
[ 4.437526] [test] tegra_dc_readl: dc->base + reg * 4 = ffffff80025e0104
[ 4.444734] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e10c0
[ 4.452049] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1000
[ 4.459353] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0104
[ 4.466683] [test] tegra_dc_readl: dc->base + reg * 4 = ffffff80025e0104
[ 4.473921] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1144
[ 4.481264] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e114c
[ 4.488610] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0e08
[ 4.495960] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0e0c
[ 4.503290] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1140
[ 4.510608] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1148
[ 4.517907] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e10c8
[ 4.525181] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e10cc
[ 4.532428] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e10c4
[ 4.539653] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e10c0
[ 4.546878] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0104
[ 4.554077] [test] tegra_dc_readl: dc->base + reg * 4 = ffffff80025e0104
[ 4.561209] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0104
[ 4.568449] [test] tegra_dc_readl: dc->base + reg * 4 = ffffff80025e0104
[ 4.575649] [test] tegra_dc_readl: dc->base + reg * 4 = ffffff80025e0104
[ 4.582892] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e00c8
[ 4.590164] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e1008
[ 4.597428] [test] tegra_dc_writel: dc->base + reg * 4 = ffffff80025e0104
[ 4.605201] tegradc 15200000.nvdisplay: DSI: HS clock rate is 192500
[ 4.617788] [test] enable dsi
[ 4.621294] [test], tegra_dsi_writel:i = 0, dsi->base[index] = ffffff8002600000, GET_BYTE_OFFSET(reg) = 48,
[ 4.632011] [test], tegra_dsi_writel:i = 0, dsi->base[index] = ffffff8002600000, GET_BYTE_OFFSET(reg) = 320,
[ 4.642516] [test], tegra_dsi_writel:i = 0, dsi->base[index] = ffffff8002600000, GET_BYTE_OFFSET(reg) = 324,
[ 4.653027] [test], tegra_dsi_readl: 11
[ 4.657487] [test], tegra_dsi_readl: dsi->base[0] = ffffff8002600000, GET_BYTE_OFFSET(reg) = 328
[ 12.294088] random: nonblocking pool is initialized
[ 27.678060] INFO: rcu_preempt detected stalls on CPUs/tasks:
[ 27.684902] 1-...: (1 GPs behind) idle=699/140000000000000/0 softirq=85/87 fqs=522
[ 27.693885] (detected by 0, t=5253 jiffies, g=-259, c=-260, q=7)
[ 27.701314] Task dump for CPU 1:
[ 27.705805] kworker/u12:0 R running task 0 6 2 0x00000002
[ 27.714234] Workqueue: events_unbound async_run_entry_fn
[ 27.720884] Call trace:
[ 27.724615] [<ffffffc000086450>] __switch_to+0xa4/0xb0
[ 27.731092] [<6666203d205d305b>] 0x6666203d205d305b
[ 36.050064] Watchdog detected hard LOCKUP on cpu 1
[ 36.054729] ------------[ cut here ]------------
[ 36.062103] WARNING: at ffffffc00013288c [verbose debug info unavailable]
[ 36.070269] Modules linked in:
[ 36.074725]
[ 36.077549] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.38-tegra #24
[ 36.085491] Hardware name: quill (DT)
[ 36.090595] task: ffffffc0010c9dc0 ti: ffffffc0010b8000 task.ti: ffffffc0010b8000
[ 36.099610] PC is at watchdog_timer_fn+0x230/0x33c
[ 36.105953] LR is at watchdog_timer_fn+0x230/0x33c
[ 36.112302] pc : [<ffffffc00013288c>] lr : [<ffffffc00013288c>] pstate: 600001c5
[ 36.121328] sp : ffffffc0010bbb30
[ 36.126292] x29: ffffffc0010bbb30 x28: 0000000000000001
[ 36.133321] x27: ffffffc0010c1b30 x26: ffffffc1f5fa2278
[ 36.140366] x25: ffffffc0010932d8 x24: ffffffc0010bbdd0
[ 36.147416] x23: 0000000000000000 x22: 0000000000000000
[ 36.154457] x21: ffffffc0010c1000 x20: ffffffc001093000
[ 36.161487] x19: ffffffc001093260 x18: ffffffc000ae3fe8
[ 36.168498] x17: ffffffc000a76890 x16: ffffffc000a76890
[ 36.175545] x15: ffffffc000a76890 x14: 0000000000000008
[ 36.182552] x13: ffffffc1ec6de940 x12: 0000000000000001
[ 36.189571] x11: 00000000ffffffff x10: 0000000000aaaaaa
[ 36.196599] x9 : 00000000000002b4 x8 : 0000000000000000
[ 36.203593] x7 : ffffffc0010e51d0 x6 : ffffffc0010d5fd8
[ 36.210570] x5 : 0000000000000000 x4 : 0000000000000000
[ 36.217502] x3 : 0000000000000000 x2 : 0000000000010001
[ 36.224432] x1 : ffffffc0010b8000 x0 : 0000000000000026
[ 36.231378]
[ 36.234726] ---[ end trace e15d1c1651c82d56 ]---
[ 36.240917] Call trace:
[ 36.244935] [<ffffffc00013288c>] watchdog_timer_fn+0x230/0x33c
[ 36.252323] [<ffffffc0000fd0c8>] __hrtimer_run_queues+0xf8/0x17c
[ 36.259838] [<ffffffc0000fd6b8>] hrtimer_interrupt+0x9c/0x1e0
[ 36.267064] [<ffffffc00084ac9c>] tegra186_timer_isr+0x24/0x30
[ 36.274267] [<ffffffc0000ecc1c>] handle_irq_event_percpu+0x60/0x140
[ 36.281987] [<ffffffc0000ecd40>] handle_irq_event+0x44/0x74
[ 36.288973] [<ffffffc0000f003c>] handle_fasteoi_irq+0xb4/0x188
[ 36.296210] [<ffffffc0000ec268>] generic_handle_irq+0x24/0x38
[ 36.303344] [<ffffffc0000ec56c>] __handle_domain_irq+0x60/0xb4
[ 36.310613] [<ffffffc000081774>] gic_handle_irq+0x5c/0xb4
[ 36.317387] [<ffffffc000084740>] el1_irq+0x80/0xf8
[ 36.323539] [<ffffffc0000e0b88>] default_idle_call+0x1c/0x2c
[ 36.330546] [<ffffffc0000e0d78>] cpu_startup_entry+0x190/0x21c
[ 36.337706] [<ffffffc000a65d48>] rest_init+0x84/0x8c
[ 36.344003] [<ffffffc000f9c97c>] start_kernel+0x39c/0x3b0
[ 36.350718] [<0000000080a6c000>] 0x80a6c000
